Injector size and FMU quest.?
Old Nov 29, 2002 | 12:52 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Ok...help me out guys!
I'm adding a 9 psi kit ATI this winter and I will also get my own custom PROM. I know I need bigger injectors but not how big......
My "non" boosted set up should deliver about 400-440 hp and for that #25 would be fine, BSFC 0,45.
The 9 psi kit adds on 50% that would be around 650 hp and that requieres #45 at BSFC 0,55.
Then If I would like to use the FMU as much as possible I want to run the lowest FP under non boost? and that would be like 37 psi ( SVO injectors ). And if the FMU gives me 90 psi the #45 would then be like #29 at 37 psi.
So am I thinking correct? would SVO #30 be the right way........
Any comment? or better anyone who knows a guy with similar setup (383 superram and 9 psi) and knows inj. size.......
Old Dec 2, 2002 | 05:28 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
https://www.thirdgen.org/techbb2/sho...hreadid=120342
92projectcamaro
Jan 18, 2016 08:00 AM
toronto formula
Nov 10, 2015 06:17 AM
Brother Al
Oct 14, 2015 06:39 AM
BAMiller
Sep 14, 2015 06:38 PM
