superchargers for TBI??
Old Nov 30, 2002 | 07:37 PM
scrawnywhiteguy's Avatar
Ok, I've been researching superchargers. And so far all the ones I've found say they're for TPI cars, will they work with TBI cars or are there any S/Cs that will work with TBI. Also, what kind of compression ratio should I run with 5-7 psi??
Tim:rockon:
Old Nov 30, 2002 | 10:46 PM
StocRoc's Avatar
I'm not sure if there are any actual "TBI Kits", but I know that if you call ATI they will hook you up. There was a guy here on thirdgen that had a ProCharger on his TBI camaro. I don't remember his name but he would be a good guy to talk to, maybe someone else will know who I am talking about.
As far a compression I personally wouldn't run any more than 9.5:1, I think around 9:1 you should really be safe. Is this a stock short block? Cast Iron or Aluminum heads?
Old Dec 1, 2002 | 01:09 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
TBI procharger
Old Dec 1, 2002 | 04:39 AM
SuperchargedRS's Avatar
Car: Camaro of course
Ati makes one for a truck, it will work the same for a third gen. check out there website, just run a search on google for ati supercharges.
Old Dec 1, 2002 | 09:47 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
read the post
Old Dec 1, 2002 | 05:53 PM
Thanks for the help. This will be on the 305 just rebuilt with forged internals. This also is several months if not more down the road, but I wanna be educated about it if and when I decide to do it.
Tim:rockon:
InfernalVortex
Apr 20, 2021 11:31 AM
Falcon50
Aug 22, 2020 03:26 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
Gordonr1973
Sep 29, 2015 11:59 AM
