Bigger Filter on ProCharger??
Old Dec 23, 2002 | 12:35 PM
StocRoc's Avatar
I was talking to this guy at a local speed shop the other day, and he told me that he has seen guys pick up around 1 pound of boost by putting really big cone filters on their superchargers. He says the filters that the kits come with are so small, that if you can fit a bigger filter under the hood then it is worth it. What do you guys think? 1 pound of boost kind of seems like a lot, but the filter that came with my kit is really small.
Old Dec 23, 2002 | 11:02 PM
StocRoc's Avatar
Come on guys I'm just curious. Any opinions on the subject? What about Willie and Maniac, did you guys notice any difference after installing your custom "air boxes"?
Old Dec 24, 2002 | 10:09 AM
maniacc's Avatar
StocRoc,
No sir, i did not notice any difference as far as boost rising (still get 10#'s @ 5500rpm. and only a slight intake temp change with the relocation of the filter.
later
larry
Old Dec 24, 2002 | 11:31 PM
StocRoc's Avatar
thank you larry, that's what I wanted to know
Old Jan 2, 2003 | 03:39 PM
'91 Formula's Avatar
Car: 1991 Firebird Formula
Engine: 383 Supercharged and Intercooled
Transmission: 6-Speed
Axle/Gears: Stock 10 bolt 3.42
I have always heard use the largest possible filter that space will allow. Makes sense. More filter area, more air flow.
I also heard someone gaining boost with a larger filter. I just ordered a 9" cone for my Vortech.
Old Jan 3, 2003 | 11:38 AM
StocRoc's Avatar
what size do you have now??? please let us know if it makes any difference
Old Jan 7, 2003 | 06:55 AM
It's on order now. I'll let you know.
Old Jan 8, 2003 | 12:54 PM
StocRoc's Avatar
Thank you sir.
Old Jan 10, 2003 | 10:02 AM
89IROCZZ4's Avatar
hey there,
I just got off the phone with Jim Secrest, the guy who installed the supercharger on my IROC (WHICH IS NOW READY TO BE PICKED UP!! YEAH!!!) and he highly reccommended that I put a bigger filter on, as it picked up 2/10ths of a second just by doing that. Go with as big of one as you can is what I got from him.
Old Jan 10, 2003 | 11:44 AM
StocRoc's Avatar
Thanks for the info. man. That guy seems to know his sh*t. I have a magazine article on his car and another yellow Iroc, it's a good article and tells all about his setup. I actually read a post on here a while ago about him, I think some guys were arguing about his setup or something. Thanks again
Old Jan 10, 2003 | 12:17 PM
89IROCZZ4's Avatar
geez ... I would have to bet that I started that thread too. I was excited about having Jim do the supercharger for me. I was actually going through the 'Tuned Port Terrors' article last night. I love that issue! He did wonders with his IROC. So yeah, I'm gonna do the filter as well and we can test it out and see how each other faired.
Old Jan 10, 2003 | 02:14 PM
StocRoc's Avatar
Cool man, please let me know. Doesn't Jim own a speed shop or something like that?? Also what kind of supercharger did you go w/?
Old Jan 10, 2003 | 04:27 PM
89IROCZZ4's Avatar
I have a 12# P600, but no gauges so I am just gonna have to go with what I was told
There are 2 things I noticed .... at 20-30 mph, it blows the tires off. AND going down the freeway, I didn't feel much of a difference!!! I'm guessing maybe because I was in overdrive instead of direct drive and because I was probably only on it 3 seconds or so. Who knows. Any ideas?
Old Jan 10, 2003 | 11:41 PM
StocRoc's Avatar
As far as a 12# kit, you're probably not making a full 12 pounds. Most ProCharged cars I see usually make a few pounds less than the pully is rated at. This also depends a lot on your current mods, the more efficient the engine is N.A. the less boost you will see. My car loves to boil the tires, and for me being on the highway is nuts. That is where my car feels strongest b/c it can actually hook up. It pulls pretty hard, and nothing beats how loud the ProCharger whistles around 5000 RPM.
Old Jan 11, 2003 | 12:49 AM
89IROCZZ4's Avatar
Ok, here's the latest::
I went with my friend to a deserted highway here with the g-tec. I was kind of disappointed, but considering the traction issue, I guess it is understandable.
My filter is dirty as anything and I had my 200 lb friend in the car with me and we pulled a best 13.05 @ 115.6. Not too impressive considering I clicked off a 12.9 @ ??? before the charger. The issue is CLEARLY traction though. I had problems before, and now they multiplied. At one point I just floored it from a stop and it went through in 3rd gear still spinning until I let off. It is definitely something I am going to have to get used to!
Without my friend, I'd hit a 12.8 and with a bigger CLEAN filter, I should hit a 12.5. Then I can start tuning and practice my launches! It's sooo depressing when you can't get on it until 4-5 seconds into the 1/4. I dropped a half second from my 1/4 just by simply practicing before.
Fireslash
Apr 11, 2016 06:43 PM
FormulasOnly
Oct 2, 2015 05:52 PM
