balancing air on diy porting?
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hey guys,
I was thikning about porting out some cylinder heads and talking to some machine shop guys about doing it. They said the hot rod shops that do that has a machine to make sur the air flow stay equal to the other ports.
Is this true?
If so how could you make sure the flow is equal when you port the heads?
thank you:hail: :hail: :hail:
Is this true?
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: balancing air on diy porting?
Originally posted by Trux
Hey guys,
Is this true?
Hey guys,
Is this true?
Transmission: t-56
ok
Thanks for the info.
I will look around for some shops that might have it up here.
Thank you:hail: :hail: :hail:
LT1Formula
20
Nov 14, 2015 12:02 AM
C409
Sep 23, 2015 04:30 PM
gixxer92
Sep 1, 2015 04:32 PM
Dialed_In
Aug 20, 2015 01:45 PM
