Got my car back this weekend after some 'cosmetic alterations' were made
Old Jan 13, 2003 | 09:10 AM
Guido's Avatar
Car: 2000 Trans Am
This was an on the fence type of modification when I decided to do it but I figured I would be pushing the speeds sometime in the near future to need one and due tothe fact that we will be painting the car and doing body work this spring, I decided to get it now instead of later and do more body work.
hehe
I know this isnt the suspension forum but I talk to a lot of people on this board and figured you guys would get a kick out of this.
So here they are!
Old Jan 13, 2003 | 10:33 AM
BlownBird's Avatar
Looks good Guido!
Where is the chute? You know you will be needing one of those soon also. This is going to be a good year for the third genners!
Old Jan 13, 2003 | 11:09 AM
Guido's Avatar
Car: 2000 Trans Am
It is another planned modification for this winter. I have other things I need to get done. Here is a list of the pile of parts I have sitting at the house waiting to be installed.
Hal 12 way adjustable shocks
Wolfe Race Craft rear anti roll bar
Wilwood heavy Duty front disc brakes
28 x 10.5 ET Drags
26 x 4.5 ET Fronts
Stuff yet to purchase:
coil over conversion
rear springs
chute
Old Jan 13, 2003 | 11:52 AM
BOTLFED's Avatar
Hey Guido,
I know this is off topic, but can you give me any more info on how you mounted your remote batter turn off switch.. I see it poking out the tailight there and it's exactly where I want to put mine..
Thanks!
Old Jan 13, 2003 | 12:00 PM
Guido's Avatar
Car: 2000 Trans Am
I dont have it hooked up actually. I think Im going to remove it from there and mount it inside the car on the front of the back panel. If that makes any sense. Then Im going to build a bracket for it to mount on, and another brakcet to bolt in place of the switch. Then a rod through the rear firewall with a handle on it to make it a push pull type.
Its damn near impossible to get the battery cables routed the correct way with the switch mounted like that.
Old Jan 13, 2003 | 12:04 PM
BOTLFED's Avatar
I know exactly what you mean... I also thought of doing something like what you're describing, only thing I would put the T handle behind my gas cap so it doesn't protrude from the car.. Wonder if it would be leagal to be under the gas cap?
Any idea?
Cheers!
Old Jan 13, 2003 | 12:21 PM
MdFormula350's Avatar
wow that fast !!
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
fonzie85
39
Mar 16, 2016 07:07 AM
mustangman65_79
Sep 1, 2015 03:51 PM
justin57
Aug 20, 2015 07:05 PM
