header question? it there any diff?
Old Jan 15, 2003 | 03:47 PM
icebird_1981's Avatar
summit has headers for next to nothing compared to what i have seen and i want to get them. but fist i want to no whats up with them there must be a resion they cost that little? are they ok to get, what i mean is it the same power gain as anyother headers out there???
part # >>SUM-G9005
Buick/Chevrolet/Oldsmobile/Pontiac: 262-400, 1 1/2 in. primary tubes, 2 1/2 in. diameter collector, headers
Old Jan 15, 2003 | 08:12 PM
TwnTrboZ28's Avatar
the cheap ones usually have thinner tubing.
Old Jan 15, 2003 | 08:14 PM
TwnTrboZ28's Avatar
or like you said they might not flow as well because the dia. of the tubing is smaller.
Old Jan 15, 2003 | 10:37 PM
bEtUr4dRustang's Avatar
Those headers are quite small. I would say they would be fairly detrimental to any healthy 350.
Try to find atleast 1 5/8 primaries if not 1 3/4s. collectors on those sized headers are normally 3inch.
Old Jan 15, 2003 | 10:45 PM
what about a 305 with 3" exhaust, still to small? i just want to get them and they turn out bad.
Old Jan 15, 2003 | 11:10 PM
well its not so bad then but if you are looking to get the most out of your 305, i would go with something larger. Hedman sells a set of shortie headers that are only $100 and i believe that they have 1 5/8 primaries.
BTW, you may not be able to just bolt any headers on without some custom Y pipe work or a Y pipe sold by the company that makes the headers. Hedman makes a really nice packaged deal. I would look into that at Summit.
Old Jan 15, 2003 | 11:23 PM
thanks for the info, saved me from a mistake. would u happen to no the part num or link i am tryin to find them and gettin no luck, are they under streed headers @ summit??
Old Jan 15, 2003 | 11:28 PM
its ok i found them thanks 4 your help.
draco
Oct 4, 2015 09:25 PM
tricky1
Aug 23, 2015 01:17 PM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
