ATTN SC and Turbo guys. opinions and insight needed
Old Jan 20, 2003 | 10:04 PM
bEtUr4dRustang's Avatar
is 6 lbs boost from a non-intercooled Supercharger too much for my hyper pistons and and 9.8:1 compression? This will be a tpi setup.
I think bhass is running high compression but how high?
Also what do you guys think of FMUs and BTMs on a tpi setup. Would you just go with a 4479 ECM from a sy/ty or turbosunbird?
This would, i think, be a temporary setup until forged pistons with a lower compression ratio, intercooler, and a smaller pulley were installed.
If this isn't a nearly safe thing...let me know cause i will wait for the forged pistons.
Thanks guys.
Old Jan 20, 2003 | 10:45 PM
bhaas's Avatar
I'm running 9psi non intercooled boost. I have a stock deck block with flat top hyper pistons and Vortec heads. I have no idea what my compression is. The compression tester says 160 psi. I can't help with TPI. Have fun.
Brad...
Old Jan 20, 2003 | 10:52 PM
thanks man...i will try to get that info sorted out.
do you know anything about the pistons? Ross Pistons has a compression ratio calculator but you have to know a few things about them and your combustion chambers etc.
Old Jan 20, 2003 | 11:10 PM
well i might as well get some comments on the SC itself. I was thinking a Paxton SN93 cause they are cheap but you do get what you pay for i guess. I am only considering running at most 7-8 psi boost with the right parts to do it.
Thought i could keep the boost low for reliability and maybe have a nice nitrous system for the tack...
Thoughts?
I read somewhere that someone was runnig dual eaton SCs for 800 bucks. How is my question.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
makaveli09
Aug 12, 2015 09:07 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
