fuel pump, stock lines, nos ----->?
I am running a holley black pro series pump. I am using the stock fuel lines with no return. I also am planning on spraying a 150 shot. Think I will have any probs? I did this with my old efi setup and was wondering if I can still get away with it using the back pump?
Drew
Drew
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I think it would help to post your approx HP numbers so these guys can better guage how much fuel volume you are requiring while running natural. I'm in the same boat, running about 460HP naturally through 30# ford injectors and I need to know if a 150 shot drawn from the shrader valve would be safe. The more opinions/examples, the better. Can't be too safe...
I am not sure yet. No dyno time, or track time yet... here are the specs to the motor though
355 10:1.1
fully balanced
afr 190s flow 267cfm
comp cam 224-230 with 535-545 1.6rr
edelbrock performer rpm
holley 750 dp
full msd ignition
full roller motor
shortie headers
3in exhaust
2800 stall
ford 9in with 3.70s
Drew
355 10:1.1
fully balanced
holley 750 dp
full msd ignition
full roller motor
shortie headers
3in exhaust
2800 stall
ford 9in with 3.70s
Drew
Car: 1992 B4C 1LE
Re: fuel pump, stock lines, nos ----->?
Drew
Drew
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
