CHP: Junkyard 350 takes 425 shot before blowing...
They took a 350 out of a junkyard, left the bottom end stock, put in a 268 Nitrous cam and new intake manifold. Got the thing to put out 599 horsepower on a 325 shot of nitrous. Then they went to give it a 425 shot and it blew. They said they think it might've been able to take a shot that big if they hadn't purged the system at as low of RPM as they did. Oh well, 325 shot on a '75 350 2-bolt main with the stock rotating assembly doesn't seem to bad.
Car: 1989 Camaro
Engine: 406
Transmission: Pro-built 700R4
That article was damn impressive. I would have like to have seen it stay togther to see if it could have taken the 425 shot. Knowing that this would never be reliable, it sure is fun to watch them flog it and see how much it would take before letting go.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
The nos is not the thing that will do in a motor.
It is the tuning mistakes ( lean/ rich/ octane/ timing ) that
break parts.....
Your mileage may vary.:sillylol:
break parts.....
Car: 1992 B4C 1LE
100 shot? probably nearly indefinitely until you made too many mistakes in fuel quality, supply, timing, or in their case rpm during activation.
I know that if you spray a 125shot continuously for about a minute you'll blow something up (I know someone that did it and lived to tell about it)
Car: 1992 B4C 1LE
thats not what I meant, im so sure...
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Originally posted by Free Bird
what did it run?
what did it run?
Car: 1992 B4C 1LE
I wish those jackholes would have had some brains during the purge so we could see what it would have made on the "larger shot". what destruction they did is basically what a regular guy could get with a hand activated nitrous switch mounted to his steering wheel or shifter without inhibiting precautions for RPM or atleast WOT.
Street Lethal
Apr 30, 2019 12:14 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
tartagliaz28
Aug 15, 2015 10:59 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
