Best Feul injectors?
Old Jan 28, 2003 | 05:37 PM
Trux's Avatar
Car: grand prix/84 z28
Engine: 4.6 Northstar
Transmission: t-56
Hey guys,
What brand of feul injector would you recomment from the 24lb-36lb range and injector around 98lb?
thanks you
just curious
Old Jan 30, 2003 | 01:24 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
Im not sure what your asking here 24-36 # per hour and 98 PSI line pressure? either way check this out https://www.thirdgen.org/techbb2/sho...hreadid=120342
Old Jan 30, 2003 | 02:21 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Bosch are supossed to be the best, but they are $500+ for 8. Its a lot of loot. The Ford and Accel injectors have a similar spray pattern to the Bosch design. A lot cheaper too and work great for most people. I believe the Ford injectors are $10 cheaper through Summit or Jeggs. Did you try a search on this subject? I see a post about injectors every other day. By the way, Bubb Rubb and Lil' Siss are the sh it! lol "Whoo-whoo"
Old Jan 30, 2003 | 02:30 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
i have bosch 26lb. Maybe for sale, if i get bigger injectors.
Old Jan 30, 2003 | 10:53 PM
Trux's Avatar
Transmission: t-56
sorry
I was asking about to different ranges of injectors, Seond range was an injector around 98 lb or so.
thanks for your help:hail: :hail: :hail:
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
