twin turbo v8 s-10
Old Feb 3, 2003 | 04:55 PM
350tbi's Avatar
twin turbo v8 s-10
I'm going to buy a new car soon. I'm thinking about buying a newish s-10 in good condition with a 4 banger in it. Drive that around are then swap in a ttsbc with a 700r4. I've had alot of experience working with turbo's mostly my turbo dsm and alot of experience working on all my friends camaro's/chevy trucks. I'm thinking this could be a bad *** ride considering how light the s-10 truck is. Think it would work, enough space.
Old Feb 3, 2003 | 08:49 PM
My90Iroc's Avatar
Car: '90 Iroc
Transmission: 5 spd
I've seen on around here, the guy brings it to the local cruise nights every so often during the winter. Pretty sick ride, but absolutely crammed under the hood. Definitely cool and unique so good luck and have a blast if you do it.
Old Feb 4, 2003 | 10:55 AM
Dan W's Avatar
I was thinking about something similar to this...
I'd start with a 4x4 S-10 though. I'd get the transfer case out of a Bravada or AWD Astro... lower it and have AWD to put all that power to the ground. I'd start with the 4.3 instead of the 4cyl. I'm pretty sure the bell housing on the 4.3 is the same as the Small block chevy so you could use the tranny that comes in the truck... I think the motor mounts are the same also between the 4.3 and V8 (you would want to verify that) .
Old Feb 4, 2003 | 01:08 PM
87Z-ya's Avatar
S10's are not as light as most people think.
Old Feb 4, 2003 | 02:52 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
3050 lbs. on my s10
Old Feb 4, 2003 | 05:10 PM
350tbi's Avatar
the main reason for s-10 is the lightness and the newer models. I've done the old car thing just too much time and money and rust drives me CRAZY. probably end up buying a 4 banger and put in a healthy small block, just have a bunch of turbo parts laying around and am playing with the idea.
Old Feb 6, 2003 | 06:37 PM
Mark W. Winning's Avatar
Originally posted by xpndbl3
3050 lbs. on my s10
Yeah, but whats in it? Without a/c and such, mine was 2700 lbs.
Old Feb 6, 2003 | 07:39 PM
lane's Avatar
My 86 s10 ext cab is 2850 lbs with a v8, 700r4 and A/C .
Old Feb 7, 2003 | 08:28 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
considering the tight fit of engine bay and the room required to TT a V6 camaro SC (sports coupe) might be more ideal. The one I built with T56, 9", 355 EFI, NOS weighed only 2800 lbs afterwords and ran 11.90's on 435 RWHP
Old Feb 8, 2003 | 03:20 PM
MdFormula350's Avatar
sounds like an awesome project to do!!
Old Feb 9, 2003 | 10:27 PM
fastredtruck's Avatar
Car: 88 gmc 1500
Engine: 496
There was one with a TT ls1 in it at the Detroit autorama last year. I think it was the same one in Chevy High Performance magazine a while ago built by Lingenfelter it was awd and ran 10s while still looking pretty stock!
Old Feb 13, 2003 | 12:50 AM
Vicious 88 GTA's Avatar
I had an 86 S10 Blazer with a healthy 350, holley 650 carb, weiand stealth intake, mild cam ( dont know the specs because I bought it like that ) dual Flowmaster with dumps, 2.5 piping, Zexel Torsen 3.42 out back, polished heads, 700R4 with a B&M shift kit and B&M Light Truck Megashifter...it ran low 14's all day long....it amazed many people that didn't know what was under the hood, I think the 2.8 Fuel Injection label under the drivers headlight threw them off
......AARON
Old Feb 13, 2003 | 01:05 AM
xpndbl3's Avatar
Car: 1984 Z28
well 3050 pounds, 4.3L, a/c, 4l60E and oh yea...me. lol It's on a 98 S-10 SS
as for your TT questions, ask for scott here:
www.powerconceptsinc.net
on employee vehicles his S-10 is there. It had a 4.3L bowtie block with ONE turbo running high 9s in street trim. He told me he could build my SS S-10 to 10s on pump gas for me. I will do it in about a year. This would be daily driver reliability too.
He also does GN motor swaps into S10s and I believe that is what is going into his white S10 next.
later
Steve
project89
Nov 30, 2008 07:18 PM
mefreema
Jan 13, 2004 11:20 PM
