Nitrous switches....
Old Feb 4, 2003 | 03:47 PM
383backinblack's Avatar
Car: '91 Camaro RS
Engine: F1R Procharged 383
Transmission: Tremec 600
Axle/Gears: moser 12 bolt, 4.11's 33 spline axl
Does anyone have a nitrous button on their manual shifter? im kinda on the fence as to where to put the damn thing. Also, does anyone have a setup with a window switch or an automatic firing setup?
383
Old Feb 6, 2003 | 06:07 PM
Mark W. Winning's Avatar
I think I have had it every which way I could think of. Currently I have 2 stages, one on an aftermarket throttle switch and one connected to the horn. I like the control it gives me. I had the window switch setup and removed it. Its very hard on the motor if you ever have to "play" with the throttle on a pass.
Mark
Old Feb 7, 2003 | 03:58 AM
Kiwi-85IROC's Avatar
Mark: What do you mean by this...can you explain why you say this?
Old Feb 7, 2003 | 04:24 PM
If you ever get a bad track or a slick street and blow the tires off it can get a bit hairy. At the time I was not running a throttle switch with the window switch and went I backed out of the gas a bit the spray was still going. The addition of a throttle switch would have corrected the issue, but since I run a powerglide I am not really worried about not spraying during a shift.
Mark
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
