Nitrous/ computer chip question
Old Feb 11, 2003 | 04:31 PM
Rhoadster01's Avatar
I wasn't quite sure under which board i should post this, but i figured you guys would know. I'm putting a nitrous kit on my camaro and need to upgrade the stock ignition setup. I was looking at different ignitions (paticularly MSD) and the only difference i noticed between the 6A and 6AL is the rev limiter. My friend told me to find out what the stock chip's rev limter is so that maybe i could save a few bucks. If anyone knows which i should go with or can suggest another route, please reply. thanks again-you guys have helped me a ton with my car.
Donnie
Old Feb 12, 2003 | 07:40 PM
88 WS6 TransAm GTA's Avatar
Car: 92 Trans Am 'Vert
Transmission: 5 Speed
Well, the stock chip doesent have a rev limiter. And dont use ANY aftermarket chips with nitrous. You need to pull timing while spraying, where as aftermarket chips add timing. Too much timing + nitrous = detonation = bye bye pistons. From what I understand, you DO NOT want to run a rev limiter while spraying either. The reason you upgrade your ignition for power adders, such as nitrous, is to get a perfect reliable spark. The last thing you wanna do when spraying is to hit your revlimiter and cut the spark... that would be catostrophic to an engine, especially at a high RPM.
Hope this helps.
Old Feb 12, 2003 | 11:51 PM
rooster433's Avatar
people need aftermarket ignition to cut spark as a rev limitor
the problem comes when the stock computer cuts FUEL and the car pops lean.
If you need the rev limitor lifted send me the chip with a return paid envolope. I'll do it for you.
Send me the Broadcast code first. its possible you don't even have a rev limitor
Old Feb 23, 2003 | 09:07 PM
360Iroc's Avatar
seems to me that my iroc has a rev limiter
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
theurge
Aug 21, 2015 12:46 PM
Bryan F
Aug 18, 2015 02:28 PM
redmaroz
Aug 16, 2015 11:40 PM
Exxon Limited
Aug 9, 2015 08:13 PM
