Mini-Ram Fuel Rails
Old Feb 16, 2003 | 02:23 PM
89406Iroc's Avatar
Mini-Ram Fuel Rails
I don't know if this is a problem for me but I had #7 run lean on a nitrous run. I am considering what I can do to the TPIS fuel rails to solve the routing of the fuel through their rais. Has anyone done any kind of line boring or replacement of their fuel rails to solve the parting wall on the rails. Thanks for all your help.
Old Feb 17, 2003 | 07:16 AM
Blownvette's Avatar
They can't be bored due to the inside shapd it is a two chamber design. I had a set opened up and welded to work. I paid $300.00 for the machinne work and I had to supply fittings. I just converted a team G manifold and sold the mini ram with the stock rails but have the big rails so if you want them let me know.
Art
Old Feb 17, 2003 | 08:39 AM
89406Iroc's Avatar
Do you have any pics. I may be interested. Do they mount the same? Is the regulator on the rails? Thanks
Old Feb 17, 2003 | 10:52 AM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I'm definitely interested in those rails too.
Tim
Old Feb 17, 2003 | 12:01 PM
89ProchargedROC's Avatar
Art
eh....wrong answer. You can bore out the miniram fuel rails. There is a guy on the blown emailing list who just did it for his twin turbo corvette. His name his doug hegge.
i dont have his website off hand...
but now i do
http://www.jdhcon.com/Vette.html
Old Feb 18, 2003 | 09:44 PM
Blownvette's Avatar
but now i do
After you do it yourself you will be qualified to correct me. Keep looking at other peoples accomplishments and replying as fact. If you know so much do it and post YOUR results.
Old Feb 18, 2003 | 11:03 PM
89406Iroc's Avatar
Can't we all just get along
Blownvette, do you have pics of your rails? Whether I can do it or not, it'd probably save me alot to get a set that are already done. Thanks
Old Feb 19, 2003 | 01:23 AM
hey jerkass...RELAX. I was just making a joke notice the "ehhhh.....wrong answer"?????
i dont have to look at other people's accomplishments i have pleny of my own and plan to back up a few of my claims this season with my motor.
I'm not just another punk around here...if you really wish to get to know me and what i built email me otherwise dont be so judgemental.
Old Feb 20, 2003 | 10:25 AM
TRAXION's Avatar
Word.
... and I am no longer interested in those rails BlownFette. I agree that the stock rails can be bored and modified. There is a center divider along the inside of the rail. Drill out this center portion and then weld an AN fitting on the back of the rail. Feed EACH rail with fuel (get rid of the rinky dink TPIS crossover tube). Run the fuel deliver to a regulator with 2 outputs. Run each output to the rail. You'll have to plug/weld the stock FPR location on the rail. This definitely can be done. Just takes some cash for the machining and welding.
Tim
Old Feb 20, 2003 | 10:37 AM
Blownvette's Avatar
Originally posted by TRAXION
Word.
Tim
When the drill bit walks and you ruin your casting remember how much everyone that has never done it knows.
Old Feb 20, 2003 | 11:24 AM
im sure trax realizes as this isn't a simple drill it out and weld it on kinda deal. It is slightly "involved." But it isn't extremely difficult either. If people would like to know how to set it up so that that what you describe won't happen either one of us would be glad to try and offer some help on how to get it done.
Old Feb 20, 2003 | 11:59 AM
Blownvette's Avatar
Good luck. The tone of the replies on this thread is enough for me so I am respectfully exiting.
Old Feb 20, 2003 | 01:41 PM
Guido's Avatar
Car: 2000 Trans Am
blownvette if you cannot maintain a respectable composure when posting here, then dont post. You turned this discussion down the dirt road.
Old Feb 21, 2003 | 12:51 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
Hey hey now... lets keep this discussion going. I'm curious about the miniram vs converted single plane topic.... I didn't know that about the miniram fuel rails.
Old Feb 21, 2003 | 02:44 AM
83 Crossfire TA's Avatar
As far as those fuel rails go, I'm not sure I see what the big deal is to modify a set (yes, I have seen some with the ends cut off and the 2 chambers). For that matter, I'm not sure why they were built that way in the first place, and I don't know why no one hasn't just built bigger rails for them using genaric fuel rail stock (yea, the hold downs won't be as nice...).
Andrew6.688
Dec 13, 2015 10:59 AM
stalkier
Dec 6, 2015 11:25 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
