Fogger system for TPI
Subscribe
Mar 4, 2003 | 09:26 AM
I have been thinking about getting a sportsman fogger kit and install it on a TPI intake but Im not sure where I should put them, does anybody have info on that or some pics?
I was thinking about putting it on the base but I dont know if I have the room and then it would take a lot to change jets on it too.
Any info would be great!
JD
Reply 0
Mar 10, 2003 | 03:27 PM
Has nobody put foggers on a TPI?
Jay
Reply 0
Mar 10, 2003 | 09:57 PM
Not familiar with the kit. Do you have a kit number or link?
-Schultzy
Reply 0
Mar 10, 2003 | 10:17 PM
Hey I had the same ideal so I called NOS they said it could be done.If you send them your runners they can weld the fittings for the foggers.I have a pic of it some where I will find it and send it to you.Hope this helps.
Reply 0
Mar 11, 2003 | 07:27 AM
Schultzy89GTA this is the kit I'm thinking about putting on my TPI if it can be done.
http://www.holley.com/HiOctn/ProdLin...SprtmnFog.html
Thanks Jack G jr I was thinking about doing my welding myself I just dont know where it would be best to put them at the top off the runners or down low.
Jay
Reply 0
Mar 11, 2003 | 08:33 AM
This is a picture of a picture, but I think it is what you are looking for.
Reply 0
Mar 11, 2003 | 08:49 AM
Here was my OLD setup w/ my TPI
Hope this helps...
Rick
Reply 0
Mar 11, 2003 | 11:55 AM
Thanks Rick - I hadn't seen that before. Wouldn't the newly designed noszles work a little better? These are the ones that the fuel injector fits into.
-Schultzy
Reply 0
Mar 11, 2003 | 02:17 PM
I called NOS about that set-up as well they told me because of the runner design with the injector & the noszzle it make it a tight fit.Maybe they have addressed this problem by now this was back when they first introduced the noszzle set-up.
Reply 0
Mar 11, 2003 | 03:11 PM
Thanks Jack.
Good Luck JD. Post which way you go.
-Schultzy
Reply 0
Mar 12, 2003 | 09:17 AM
Thanks Skweezn87
It looks like it is a lot of work and it looks like you have to have different fogger, because it looks like you cant use ones that come out the side off the fogger.
I will let you guys know how things go or if I will do it.
Jay
Reply 0
Mar 12, 2003 | 10:49 AM
Does anyone know how well the "NOSzle" system works? I was looking at this kit for my new motor, but it is a pretty expensive and I want to make sure I will be happy with it. I will be using it on a stealth ram intake.
Reply 0
Mar 14, 2003 | 01:24 PM
The foggers that are in there are your normal foggers.. but the end is snapped off.
Thats the way it came from NOS. I was surprised to see this..but it worked damn nice.
Rick
Reply 0
Subscribe
