Wastegate placement ideas
Old Mar 7, 2003 | 02:34 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I was just on the phone with a guy from Turbonetics chosing my turbo.. which will be: 62-1 P-trim w/.81 ext.
Anyway. He was saying that the wastegate needs have the exhaust gases pushing against the valve. Also in order to ensure I do not get boost creep it should be plumbed into both banks. It seems to me that this could be a little tricky. I have come up with the following 2 ideas. I am not sure how much I can raise the turbo until I have it in my hot hands so we shall have to see.
What do you guys think the best option is?
Old Mar 7, 2003 | 04:39 PM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
Transmission: 6spd auto
Axle/Gears: Rotating
you need to make sure it vents pressure FROM ALL EXHUAST PORTS equally to get the best effect from them
best idea I can really come up with is to put the wastegate after the collector and then the turbo after that
Old Mar 8, 2003 | 01:26 AM
Omega's Avatar
Engine: LS1 / LS3
In this picture, the wastegate is the blue item. The orange block is after the "collector" so the wg is feed by all cylinders.
Would the configuration I have be acceptable for the "exaust gases pushing on the valve" as the tech guy has recomended?
Old Mar 8, 2003 | 01:51 AM
rx7speed's Avatar
Car: 2005 BMW 545i
Engine: 4.4L N62B44
this is about the opitman placeemnt from what I udnerstand
rather hten having the wastegate branch off at a 90 angle it is best to have it both the turbo and the wastegate share the same angle away from the collector
also it looks like your using a log style manifold for your turbo... not the greatest idea. works but not the greatest
that is hwy I kinda made a drawing with headers
oh and sorry I'm half asleep so the drawing looks like somethinga 1st grader could do better with
83 Crossfire TA
Jan 3, 2016 01:26 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
