Weiand 177 retrofit
Old Mar 11, 2003 | 03:08 PM
jRaskell's Avatar
Weiand 177 retrofit
Could a Weiand 177 be retrofitted to a TPI engine? Would it bolt to the TPI heads and clear the distributor? I know a bonnet could be made to mount the throttle body to the supercharger itself Outside of hood clearance issues, what other issues would be involved with such a retrofit? If not the Weiand, is there another roots style supercharger in the sub $1500 range that would make a better retrofit candidate for a modest 6psi boost application?
Old Mar 12, 2003 | 11:12 PM
dans82bird's Avatar
Car: 1988 Mustang GT
Engine: 302
might want to look up what Saturn5 did... he took whipple blowers breathing into tpi :hail:
Old Mar 13, 2003 | 12:03 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
Saturn5 used 2 eaton m90 superchargers...not wipple screw sc's...which are way different
Old Mar 13, 2003 | 09:38 PM
Damon's Avatar
Not on 87-up intake bolt pattern heads. Weiand blowers only work with the earlier 86-down intake bolt pattern. The nearly identical Holley 177 blower might be able to be purchased with an 87-up intake bolt pattern- contact Holley and ask them.
Yes, it will clear the distributor, even a large-cap HEI.
JSDaddy189
Sep 26, 2015 03:50 PM
Dragonsys
Sep 25, 2015 03:51 PM
anesthes
Sep 18, 2015 12:34 PM
TexasMaro
Sep 15, 2015 06:50 PM
R3500
Sep 8, 2015 10:12 PM
