Pull type electric fan on IC?
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
I am looking for some feedback from the experienced FI guys. I am going to rip the crank fan off of my crank pulley(on my TTA) thereby creating some room to mount an 8" electric pull type fan on the backside of the IC. With the closed nose of the TTA I am hoping it will dramatically enhanced the flow of air through the IC.
If any of you FI guys know what I'm talking about in reference to this car please chime in.
Thanx,
Pete
Thanx,
Pete
Car: 89 Formula 350
Engine: 409 nitrous' small block
Dunno bout your particular application, but a lot of people use electric fans on their intercoolers. Basically intercoolers function just like a radiator, so the more airflow you get across them the better.
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
It is actually a really good idea - more air across and intercooler will bring the efficiency higher. But you need to get cool air from outside the car thru it - not hot air from the radiator.
Hey Pete, do you go on turbobuick.com? There is lot of info there under the TTA section. You will be able to get answers there as far as what works on TTA. My buddy's TTA ran 11.22@ 118mph. his mods are; TE 63 turbo,3"downpipe w/two deltagate setup, full race trans w/ Art carr 9" nonlockup converter, MSD 50# injecters, Translator Plus,340 fuel pump adj reg an a stretched stock location IC.
Good luck
Prasad
Good luck
Prasad
Car: 1992 B4C 1LE
the DSM's that add FMIC's run electric fans.
