150 shot and hyper pistons
Old Mar 25, 2003 | 10:16 PM
badazz84camaro's Avatar
will hyper pistons take a 150 shot?
Old Mar 25, 2003 | 10:17 PM
87transam5.7tpi's Avatar
I woldn't do it unlee they are Keith Blacks. and then I think i'd only doa 100hp shot
Old Mar 25, 2003 | 11:42 PM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
i've ran a 150 shot on kb hypers just keep the tune safe (timing/fuel psi)
Old Mar 26, 2003 | 12:51 AM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
I have run several bottles through a 150 shot on a stock L98. I believe those are cast. You should be fine with the hypers w/150.
BTW, the boys at Shafiroff call that a 'play shot'. hehe. Must be nice to play with the big toys.
-Schultzy
Old Mar 26, 2003 | 01:19 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
Yes, running a 150 Hp shot is possible with a dry system but will be more reliable and durable with a wet system. But both will reduce the durability of your engine. Reliability is in reference to early hour failures and durability is in reference to the useful life of your engine.
Old Mar 26, 2003 | 01:22 AM
QwkTrip's Avatar
COTM Editor
Car: '89 Firebird
Engine: 7.0L
87TransAm5.7TPI, is that the Harwood cowl hood on your car? If so, how did it fit and how well do the edges match up?
Thanks.
no green
Jan 9, 2016 09:22 PM
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
jaridjohn
Oct 5, 2015 07:01 AM
