stealth ram & d1sc
stealth ram & d1sc
for all of you running the ram and sc will the 36 lbs injectors that come with the jeg's set-up support HITHERE sc 383 set at 15 to 20 psi according if HITHERE am at the track or on the street.ANY advice would be helpful.THANKS
jack
jack
Car: 1990 IROC Z
Engine: blown 390 CI
Transmission: TKO II
No-I doubt that 36's will cut it-at least not at a 12:1 A/F ratio. I have a 383 with 12 lbs. and 72 lb. per hour injectors and they are close to max pulse width.
