rebuilding NX nitrous solenoid
Old Apr 7, 2003 | 07:56 PM
mattRS's Avatar
once you get the main black cap off, how do you get the main cylinder out?
Old Apr 8, 2003 | 12:58 AM
sleepybu's Avatar
Car: 81Malibu
Engine: SBC 355
Transmission: TH400
good ?
Old Apr 8, 2003 | 01:45 AM
onebadwagon's Avatar
did you try to get NX to fix it? they do have a lifetime warranty, id try that, before i screwed with it.
btw, get that 350 in yet?
adam
Old Apr 8, 2003 | 03:06 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
did you get a rebuild kit with a new seal and plunger?
Old Apr 8, 2003 | 11:15 AM
mattRS's Avatar
its not the solenoid thats messed up, not the workings as least. smoebody screwed up the wiring and burned it up, hoping i could re-wire it instead of sendin it in.
building the 350 right now, should go in in june
Old Apr 8, 2003 | 06:36 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
you just need a new coil. That can be changed without even removing the selenoid. it can be tested too, how do you know its bad, visible burning? how do you wire one wrong enough to damage it, do you have something higher than 12 volts on your car? were you missing a ground on the engine and it grounded through it with too much current?
Old Apr 8, 2003 | 10:58 PM
mattRS's Avatar
i cant see any damage. it was on a friend's car and he messed up the wiring. it was blowing fuses everytime he hit the button, and once it purged for a second then stopped, and nothing after that.
Old Apr 10, 2003 | 12:36 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
usually it is the wiring, usually related to running the nirous system with all the current going through the tiny switch instead of a relay but not always
Old Apr 11, 2003 | 02:58 AM
mattRS's Avatar
its a possibility...i'll hook it up to direct 12 volts tomorrow and see what happens.
Old Apr 11, 2003 | 06:01 PM
mattRS's Avatar
put it to direct 12 volts today and nothing happened. any other ideas?
Old Apr 11, 2003 | 08:42 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
send it back?
Old Apr 11, 2003 | 11:37 PM
mattRS's Avatar
will they still take it if i dont have a receipt?
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
