FAST eDIST with FAST SEFI and LS1 Coils
Old Apr 19, 2003 | 11:15 AM
Monty's Avatar
Car: Old Car - 1982 Vette. New Car - 1972 Vette Convertible
Engine: Old Car - 1200hp TTSBC 427. New Car - TT LS7X
Transmission: Old Car - 4L80E. New Car - TBD
I know this isn't a forced induction or nitrous specific questions, but I know there's more people here running aftermarket engine management than most anywhere else...
I am currently running a FAST sequential EFI with a crank trigger and a modified MSD distributor for a cam synch signal(reluctors removed except 1) and conventional MSD ignition.
I recently purchased the FAST eDIST LS1 "Direct Fit" 30-5001 distributorless ignition box, as well as the MSD distributor plug with cam synch, 8514. I will be using 8 LS1 coils.
The MSD cam synch plug is hall-effect, do I have to send my FAST SEFI back to FAST to have it setup for hall-effect cam synch? Also, the MSD cam synch has a 4-pin metripak connector, does anyone know what the pin outs are for it?
Anything else I need to know? Thanks!
Old Apr 19, 2003 | 11:35 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Might want to chat with Grumpy. His GN has eDist and LS1 CNP coils with the OEM 148 ECM.
Old Apr 21, 2003 | 10:11 AM
87Z-ya's Avatar
go to the fuel injection board at www.chevytalk.org craig should answer that for you.
Old Apr 21, 2003 | 10:27 AM
Monty's Avatar
Thanks, I tried there as well. I was just hoping to get a head start on this thing over the weekend.
Well, if anyone is interested, the pin outs for the MSD 8514 cam synch distributor plug is:
A = Not Used
B = Ground
C = Hall-Effect 5v input(+)
D = Hall-Effect Signal (-)
SPEEDY Z28
Brakes
16
Apr 18, 2016 02:46 PM
RedLeader289
Sep 23, 2015 06:50 AM
dbrochard
Sep 19, 2015 08:13 PM
timonator
Sep 17, 2015 06:57 PM
Jlanz55
Sep 6, 2015 03:05 PM
