o-ring the block and heads?
Old May 26, 2003 | 11:26 PM
AFast83z28's Avatar
I don't know if this is the right forum but I figured I would go ahead and ask. I am building a 377 for a large sized turbo. Should I o-ring the block? Should I o-ring the heads? i REALLY REALLY do not want to tear apart the short block again so I want to be prepared. Plus it can be done locally for a decent price so I figured I would go ahead and ask!
Old May 27, 2003 | 03:34 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
If it is cheap enough locally do it..it is good insurance with a turbo motor.I would also recommend to use ARP head studs for your application.I built a healthy 355 for spray and went with head studs just for that added clamping force.Can never be to cautious.
Old May 27, 2003 | 04:54 PM
AFast83z28's Avatar
I will probably go ahead with it then. I planned on using ARP throughout. I will probably use mainly studs but some bolts I am sure.
Jake_92RS
Jan 28, 2020 10:37 PM
bamaboy0323
Sep 3, 2015 06:07 AM
Ducati900ss
Sep 2, 2015 09:05 AM
gixxer92
Sep 1, 2015 04:32 PM
lakeffect2
Aug 23, 2015 08:44 AM
