My water injection setup.. (in progress)
Old Sep 5, 2003 | 06:48 AM
  #51
BOTLFED's Avatar
Originally posted by MikeC.86Roc
Maybe I missed the injector type and Bottlefed is using water injectors??
Nope, I'm using the newer style ford fuel injectors.. People have used fuel injectors as water injectors with great success.. Just make sure to check them every once in a while to make sure they're still functioning..
Cheers,
Old Jan 12, 2004 | 09:28 AM
  #52
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
ATTN GRUMPY:
One nice thing about various ecm codes is that they have things like changing the wastgate solenoids duty cycle as a function of knock. So while you can rely on the knock sensor to trim back on timing if the WI fails, you can also use the wastegate strategy to turn on more water.
I was thinking of this myself. You think the '749 and $58 code I switched to, can either 1) turn water injection solenoid on at a certain boost level, or 2) turn it on at the hint of detonation?
-- Joe
Old Jan 12, 2004 | 10:20 AM
  #53
TTA 1387's Avatar
Car: 89 20th Ann. TA
Engine: Turbo 3.8 V6
Transmission: 200 4R
Try this:
http://www.alkycontrol.com
Its a very nice progressive kit. I'm probably going to go that route when I decide to sell my SMC kit.
Old Jan 12, 2004 | 10:27 AM
  #54
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Try this:
Too much money.. I want the ECM to control the solenoids.
-- Joe
Old Jan 12, 2004 | 10:37 AM
  #55
TTA 1387's Avatar
-- Joe
Its relative. Its a complete kit. But its working off of sensors to trigger. Which makes it just about perfect. And being varible, doesn't flood at part throttle.
I've had mine for about two years now. It works but the part throttle chug is what I'd love to get rid of. As mine is all or nothing.
Old Jan 12, 2004 | 11:10 AM
  #56
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Why would it be on at part throttle? You make boost under part throttle?
-- Joe
Old Jan 12, 2004 | 11:29 AM
  #57
TTA 1387's Avatar
-- Joe
Yes. I have it starting to spray around 10psi. It sprays the same at 10psi as it does at 23psi. That's the beauty of a progressive kit. The more boost you make, the more it sprays.
Old Jan 12, 2004 | 11:39 AM
  #58
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: ATTN GRUMPY:
-- Joe
Why bother with the ECM.. Just feed the MAP signal into a LM339 comparator and use a pot to adjust the voltage to trigger the solenoid. BW
Old Jan 12, 2004 | 05:38 PM
  #59
anesthes's Avatar
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hrmm.. Have a schematic of this? LM339 available at radio shack?
-- Joe
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
sheachopper
Jul 31, 2019 11:27 AM
NZKnight
Oct 15, 2015 02:47 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
