Turbo housing + fab work = sudo S/C?
Old Jul 2, 2003 | 10:21 AM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
To gain a couple #'s of boost, why couldn't you take a smaller turbo housing say a t25(cheap), fab up a pulley and mounting bracket for it and run it from the belt just like a S/C. With a smaller pully would it turn the turbo fast enough to be worth while? There's got to be a reason that someone hasn't done this before. Maybe its because the benefits wouldn't be very high? I'm thinking you could get 2-5#'s of boost for a couple hundred dollars. Please tell my why this wouldn't work.
Phyte
Old Jul 2, 2003 | 10:32 AM
BOTLFED's Avatar
I believe that there is a mailing list about this.. But one thing you have to remember is that turbos spin at 80,000 rpm and up so it makes it a little difficult to fab...
Cheers,
Old Jul 2, 2003 | 10:48 AM
Phyte's Avatar
Car: 92 Z28
Engine: 350tpi
Thats why I mentioned the small pulley. It would have to be about 1-1.5 inches in size and I'm not sure if thats even feasible. I don't think you could get a belt to stick to that. Also you could use a gear setup to increase the RPM to the turbo, but I'm not sure what gears wouldn't grenade at 100,000+ rpm
Phyte
Old Jul 2, 2003 | 10:50 AM
Guido's Avatar
Car: 2000 Trans Am
he bearings in a turbo are not built for the side loading that a tensioned belt would put on it.
Someone on this board from over the water has done it before, and it looked awesome but it was a LOT of work and more trouble than it was worth in my opinion.
Old Jul 2, 2003 | 11:00 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
someone posted one of those here, the guy might have been overseas he used a wheelchair gearbox, etc...
https://www.thirdgen.org/techbb2/sho...ght=wheelchair
Jeremys87
Jul 14, 2022 09:08 PM
Terrell351
Jun 13, 2021 01:13 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
db057
Aug 22, 2015 08:17 PM
perZ
Aug 15, 2015 01:17 PM
