Supercharger & Pistons
Old Jul 6, 2003 | 10:45 AM
ZRATED1994's Avatar
Would it be okay to use a supercharger producing around 9lbs of boost with flat top pistons or would that threaten the bottom end with that kind of compression? How much would flat top pistons alter the compression ratio?
Old Jul 6, 2003 | 11:06 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: Supercharger & Pistons
That all depends on what the comp ratio is..
What is the chamber volume?
Head gasket thickness..
Is the piston @ zero deck or below?
With iron heads.. 9 to 1 is about as high as I would go.
With alloy heads.. possibly 10 to 1.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
hartsmike
Oct 2, 2015 07:11 AM
Dragonsys
Sep 25, 2015 03:51 PM
