Accel Pro-Ram
Old Aug 29, 2003 | 12:00 AM
jnjspdshop's Avatar
Accel Pro-Ram
Well kind of decided I want to use a pro-ram manifold for the new blower motor I am building. I have a question about throttle bodies. Which would be the best to use for a blower application. Should I purchase the Accel/Lingenfelter plenum adapter and use the Accel 1000cfm TB I have laying around, or should I purchase a TB from Accufab, with all the assorted conversion parts? It looks like the Accel would be more cost effective, cause I already have the TB, but the adapter is 300.00 for a cast 90° elbow. Will the accufab make more HP/torq? and if I do choose accufab what mm 70, 80 or 90 mm
Old Aug 29, 2003 | 01:03 AM
89ProchargedROC's Avatar
i thought accel wasn't making their adaptor anymore....where have you seen it advertised?
this is my setup:
http://home.earthlink.net/~tt3rdgen/intake.html
its a victor junior converted with a precison turbo elbow
both the intake and the elbow have been milled to fit under the stock hood
Old Aug 29, 2003 | 09:00 AM
jnjspdshop's Avatar
Was the top or bottom and sides of the victor manifold milled?? How much was taken off?
Old Aug 29, 2003 | 09:56 AM
.850 was cut off the elbow and i honestly dont remember how much was taken off the intake. It was milled flat and then down. Next time im at the garage i can measure the height of it and let you know
Old Aug 31, 2003 | 08:05 AM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
Good luck finding the Accel elbow. But I know of a place where you can get a aluminum sheetmetal version of the Accel elbow Runs about $800 just for the elbow.
I had the Accel one and ran the 58mm tb on my ProRam. I wanted more airflow so I swapped it out for an PTE elbow and 90 mm Accufab. Was cheaper to change everything than buy the monoblade from TPIS or ASM. Picked up more hood clearance too.
Chris
Old Aug 31, 2003 | 10:34 PM
biggtime's Avatar
You can get a 90 degree elbow from these guys (200.00). then buy the
accufab throttle body. Makes fabrication allot easier.
http://www.youngsperformance.com/induction.htm
Fanatic1074
Oct 3, 2022 05:57 AM
WejaZ28
Oct 3, 2015 07:38 PM
efiguy
Sep 27, 2015 01:30 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
