im putting in NOS, got ?'s
Old Sep 7, 2003 | 09:46 AM
T/A_SXracer's Avatar
Car: '85 T/A
Engine: 385 full roller
ok, i bought a nos 150 kit from a friend of mine. it is currently set up for a carbed car, which mine is. i was just wondering what all ill need to do to run the nos? Can i splice off of the stock fuel line for the extra fuel.? Allso, can anyone tell me how well my engine will hold up, and what i should set the timing at? The engine is a fresh (about 7,000miles) 355. it has a forged crank, but only cast pistons.
also, i will be going tpi by the end of this year, how hard is it to convert a carb kit to one that will work for tpi? can i just buy an injector plate to go between the throttle body and plenum?
Oh and one last thing, i got this kit with a filled bottle for 250 dollars, is that worth it?
thanx in advance for all help.
Old Sep 8, 2003 | 09:28 PM
Car: '85 T/A
well, i got it all in today, so i hope someone can tell me where to draw fuel from. if i still have a car by then anyway. i feel like a total dumb as#.! after i put the plate under the carb, i forgot one very important thing in reasembly. THE FUEL LINE. it blew gas all over my block, and one of my spark plug wires has a small slit in it, just enough to ignite the fuel. i had like three foot of flames coming out of a closed hood. not good.
Old Sep 8, 2003 | 11:09 PM
SweetS10v8's Avatar
Car: '89 Formula 350 & '86 Z28
Engine: L98 & 355ci
Transmission: 700r4 in both
Re: im putting in NOS, got ?'s
Splicing depends on your fuel pump. I spliced Summit part #MOR-65160(pictured), but I had an electric pump(high psi) regulated down for the carb.
I spliced the nitrous fuel line before the regulator for the carb, then added another regulator to adjust the nitrous fuel pressure to where I wanted it.
Amount of nitrous will be limited by cast pistons. I havent run nitrous on anything but forged pistons, so someone can answer that better than I can.
Timing as a rule of thumb is retard 2 degrees for every 50hp of nitrous added. If you got everything you needed for $250 I would say its a good deal!!!
I am also in the process of changing my NOS Cheater kit over to a TPI kit. Im trying to find the plate, should be the same thing, just instead of hooking to a carb plate, your hooking to a TPI plate, I think...lol Ill tell ya when I find out.
Old Sep 10, 2003 | 02:21 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
Do you have a fuel pressure safety switch out of curiosity? I would definately run one if you plan on running the nitrous and your motor off the same pump. I would spend the 15 bucks for 100 horsepower pills so that you can get your car dialed in on a smaller shot.
1992 Trans Am
May 10, 2023 07:19 PM
Jake_92RS
Jan 28, 2020 10:37 PM
69 Six Pack
Oct 5, 2015 07:51 PM
fasteddi
Sep 2, 2015 10:29 AM
92firebirdchris
Exterior Parts for Sale
Aug 14, 2015 11:56 AM
