kid wanting to blow himself with nitrous
Old Sep 16, 2003 | 12:06 AM
Drop Top Iroc's Avatar
Car: 88 iroc Z28 Conv
Engine: stock 305 for now
Transmission: new 700r4
Jus Kiddin, but seriously i have a 305 iroc and am looking into a 100-150 nos kit. I have a set of dump valves on their way. my pop says all ill do is blow up my engine becuas eof the age but it was driven very seldomly be my grandfather and is in good condition and he doesnt really no crap about cars. Im intending on putting in a high output ignition
Any Suggestions?
high perf. fuel pump
Any suggestions?
cams if i need it
suggestions?
Also what should i check for wear
and i need advice on timming issue thanks
Old Sep 16, 2003 | 12:14 AM
also my whole power trian is stock
Old Sep 17, 2003 | 01:12 AM
Ions91Z28's Avatar
Car: 1991 Camaro Z28
You probably didn't get an answer yet to this post because it's not worded well. Add in that nitrous is all over the message board and a search would lead to all your answers... and responses get slower.
305s are not known for being the best at nitrous, however, nothing your dad can say will determine if it'll blow up. Nitrous is safe when used correctly.
I would recommend 100 shot for starters. Retard timing 1-2 degrees and maybe a colder plus. Check nitrous company recommendations. Your ignition needs to be in good shape, and your fuel system needs to be in good condition. Nitrous is rarely the problem when engines fail. It's ignition or not enough fuel which leads to detention.
On 100 shot, I really don't think a new fuel pump is needed, be sure to use a wet shot as well. I'm not sure which supplier you've choosen.
Cams? You can run a stock cam. If you want to change your cam your welcome to. Of course there are nitrous cams... but for a 305 TPI on 100 shot, it's not worth the time.
No problems on your powertrain. Your not going to break anything so don't worry. There are plenty of 350s running 150 shots on slicks and holding up just fine. Your 305 isn't going to be a problem.
Hope that helps you
Old Sep 19, 2003 | 02:16 AM
thanks
thanks it does
Old Sep 23, 2003 | 10:52 AM
vwdave's Avatar
A wise man once told me....
"Nitrous is only Dangerous when mixed with Stupidity."
What engine/Fuel system are you using?
Ghettobird52
Jul 5, 2024 11:18 PM
RazorN8
Jan 7, 2022 11:44 AM
86White_T/A305
Aug 17, 2015 12:16 AM
jackhammer
Aug 15, 2015 10:04 PM
sreZ28
Aug 14, 2015 07:48 PM
