Question on Trim Sizes
Old Oct 27, 2003 | 03:37 PM
johnsjj2's Avatar
Car: 1991 Z-28
Transmission: T-5 (gonna buy the farm)
I have a turbo off a Cat LP engine. It has been measured to approx. the size of a T-64. No one can tell me what it is exactly. Cat won't, Garrett won't, turbo shops can't find anything. I was looking at some turbos (T6 series) and noticed they had about 7-8 blades on the wheel, and were more straight than angled in reference to 90* from the shaft. Mine has 15 blades all the same size, and are really laid over on the inducer side, but straighten up quick on the exducer side. I would post pics, but the turbo is at home, I'm at work. Anyone know what effect the blades being laid over will have on spool time, or efficiency?
Old Oct 28, 2003 | 08:48 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I dont really have a technical answer for you (those are sure to come). I do know that the procharger P1sc-H with the helical impeller is for more low RPM boost (efficiency) at a sacrifice to high rpm boost (efficiency?) compared to the regular P1sc with its very straight cut outer blades. I hope that helps some. Makes sense to me considering the diesel application.
Old Oct 28, 2003 | 12:34 PM
johnsjj2's Avatar
Car: 1991 Z-28
To make sure I understand you right, the straight blades are more for upper RPM efficiency, the more layed over or helical blades are for lower RPM efficiency. If that is the case, I wonder how fast I can get this thing to spool to keep the low RPM boost going.
Old Oct 28, 2003 | 01:09 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes that is my belief and I dont know
Old Oct 28, 2003 | 10:13 PM
83 Crossfire TA's Avatar
To greatly oversimplify things, straight blades work better at higher pressure ratios where curved blades typically work better at lower ones (which is what we want, for turbos “higher pressure ratios” is in the 45psi range)
Old Oct 29, 2003 | 10:29 AM
johnsjj2's Avatar
Car: 1991 Z-28
Gooooood!! Then I am using it! Thanks for all your help guys. I'm looking at no more than 12-14psi, unless I'm feeling ballsy.
toronto formula
Nov 10, 2015 06:17 AM
Linson
Aug 21, 2015 02:12 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
knight72
Aug 10, 2015 09:32 PM
