24 pound injectors
Old Nov 14, 2003 | 10:32 PM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
24 pound injectors
I have a 1988 camaro paxton supercharger with about 9-10psi,trickflow heads,comp cam 220/230 dur 114 lsa 2600 stall nonlockup stock tpi and chip,with 3.42 gears hooker headers borla catback.problem is that when i am 3/4 throttle it will ping but if i put that nos octane boost in the ping will stop.is the injectors to small.timing set at stock 6 degrees.will 30 pounders stop these.fuel pump is walbro 340 with hotwire kit.do not like to retard timing.also i have colder sparkplugs installed.
Old Nov 14, 2003 | 11:52 PM
Justin 87 GTA's Avatar
Car: 1987 GTA
Engine: 645hp/656 ft lb Blown 383
Transmission: 700-R4 3,000 stall
Axle/Gears: 3.55 moser 12-bolt
i have the walbro, what is the hotwire kit? and i doubt that 30 lb injectors will help you. lower compression, run race fuel, cooler plugs, intercooler/water injection/ nitrous, timing retard,. lower boost, ..........those are all good start points, the paxton is not efficient and creates tons of heat . good luck
Old Nov 15, 2003 | 01:01 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
what chip is it? what method of extra fuel delivery is being used when the blower is boosting/
Old Nov 15, 2003 | 12:02 PM
antoine's Avatar
i still have a stock chip,and the fuel pump with the hotwire kit is fuel pump is powered from the back of the alternator with 8g wire to pump it gets a full 14volts.look at www.racetronix.com
Old Nov 15, 2003 | 12:58 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
well you either need a custom chip to add the fuel, a 749 ecm swap with a custom chip (it senses boost and ads fuel accordingly), or you need an FMU like was supposed to be supplied with your kit to raise fuel pressure a bunch as boost comes up.
here:
https://www.thirdgen.org/techbb2/sho...&highlight=fmu
Old Nov 15, 2003 | 01:11 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Are you using a FMU to add more fuel?
I think you should swap the fuel pump out for performance one, your combo sounds pretty mean to be using a stock pump. Might also be a good time to start learning to program your own chips before you blow that engine, but for now you could set your base timing back a little then see if you can find someone with a WBO2 to see where your at.
Old Nov 15, 2003 | 02:42 PM
antoine's Avatar
i have a walbro fuel pump installed. no fmu
Old Nov 15, 2003 | 07:29 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
solution, use a method listed above to add more fuel. Also not listed above, super fueler or aftermarket ECM.
Old Nov 15, 2003 | 08:18 PM
biggtime's Avatar
I have a ati fmu i could sell you.
Old Nov 15, 2003 | 10:04 PM
Car: 1987 GTA
what type of power does the walbro pump that i have support without the hotwire kit? Does it hurt the pump to hotwire it? will it not last? thanks
Old Nov 15, 2003 | 10:39 PM
antoine's Avatar
check on www. racetronix for info
Old Nov 30, 2003 | 03:56 PM
Racetronix's Avatar
The Walbro pumps will handle 16V w/o a problem.
With the HW harness it will get about 13.5-14.0V all day which is the sweet spot for the pump. Factory spec is rated at 13.5V. The HW harness can actually extend pump life.
http://www.racetronix.com/product/RX..._Pump_Kit.html
92-Formula
Dec 12, 2015 10:34 PM
beltran89
Theoretical and Street Racing
46
Oct 7, 2015 07:36 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
tgp1990
Sep 4, 2015 06:24 AM
