NOS Sniper nitrous oxide system question..
Old Nov 20, 2003 | 01:12 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
does the Sniper bottle have a diffrent valve and fitting on it?
compared to the other N2O systems i mean..
Old Nov 21, 2003 | 12:50 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
anyone??
heres why i ask:
from here:
http://store.summitracing.com/partde...rt=NOS%2D07004
This new Sniper nitrous oxide system is just what you need when you want extra horsepower, without the extra cost. Adjustable from 50 to 150 HP, it uses a standard medical grade type valve on the bottle, and has a natural aluminum finish on the carburetor plate. This kit includes a 10 lb. capacity nitrous bottle, aircraft-quality stainless steel braided hose, an injector plate, solenoids, and all other electrical and mounting hardware needed for a complete installation.
is that normal??
Old Nov 21, 2003 | 01:34 PM
unknown_host's Avatar
Car: 1989 Iroc Z L98
That valve looks way different than my valve on my NOS 10lb bottle. I would imagine its not the "high flow" valve or whatever. I always thought that the powershot solenoids were the only thing that limited that kit to making more horsepower. If I had it to do all over again (and didnt get a free kit), i would have gotten the NX Hitman kit for right around the same price.
Old Nov 21, 2003 | 01:36 PM
Here is another pic of the bottle:
Old Nov 21, 2003 | 02:32 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
YES!!! , the sniper has a valve called a CGA326 which is a standard style medical nitrous valve. it has the ability regarless of what NOS says to flow a great deal of nitrous. These valves are used after a chromating/nickel plating process by NX and a few other companies as a standard valve in all thier kits. NOS usually uses a CGA660 which is a larger pattern valve. although the bottle valve itself wont fit from adapter to adapter, the bottle will fit in a bracket and the adapters are made to fit -4 and -6 nitrous lines. I know quite a few guys that own a variety of bottles using both patterns and they have two bottle adapters to put them in the car.
Old Nov 21, 2003 | 02:59 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
ah. cool, thats the answer i was looking for. thanks.
btw, does this mean if i raid the local hospital, i can hook up a biiiig tank to my car?
Old Nov 21, 2003 | 03:01 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yes by all means get your self arrested and go to prison for $200 worth of nitrous.
Old Nov 21, 2003 | 03:03 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
lmao, i didnt say steal.
athough my question still remains... other then it might not having a DOT stamping, can a medical nitrous bottle be used?
because if i can find where to buy one, its probly alot cheaper then a racing shop....... not to mention, since they are often transported full, they probly DO have the stamping...
Old Nov 21, 2003 | 03:04 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
the only bottles a hospital or dentist has are huge iron 90P bottles which are over 5 foot long and way 250 lbs or so.
Old Nov 21, 2003 | 03:39 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
damn. i was hoping to find like... i donno the same size as the O2 bottles they have..... you know the ones the same size as a 10lb bottle, or the 15lb bottle only they're slightly diffrent shapes.....
*shrug*
in anycase, thanks for answering my question.
Old Nov 22, 2003 | 12:42 AM
83 Crossfire TA's Avatar
I've got a few hospital 5Lb bottles. They are STEEL, but only about 4" in diameter...
Old Nov 22, 2003 | 09:51 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah I had only seen those for O2, I guess they do them blue too?
Old Nov 22, 2003 | 12:54 PM
I don't remember, my brother has it now, but it's a darkish blue or green and it's about as long as a 15lb N2O bottle... I can look the next time I'm up there if it's important
junior419
Apr 7, 2025 11:35 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
