ive got a few questions one i have a speed density camaro a 91 350 tpi what is wrong with me installing nitrous on this ecm system? some people have said it doesnt work well or something and 2 can anybody post some pics of where they have there bottles hidden or not hidden id prefer to see where people hid theres so i can get an idea
B4Ctom1
close
says who? no probs putting teh ny-trous on this baby.
as far as bottles, there is already a huge post on "bottle location" that can be found using a variety of words using the search button.
If they are talking about dry shot systems then they are right. Don't go there. Get a wet system and a 150 shot and enjoy yourself.
Most common bottle locations are in the rear where the spare tire is, on the rear deck in the hatch and behind one of the front seats.
There are a lot of pics and discussion already posted as mentioned above. FWIW mine is in the spare tire well...
EDIT: I see in your sig that you are putting a new motor in. The 150 shot was assuming you were stock. What are you building and what are you going to do with it?
-Schultzy
-Schultzy
man, make that sig picture smaller, we don't need to start that obnoxious crap on this board...
wet kit is fine....for best uses you want the valve facing towards the front so up above the gas tank or in the spare tire well is best. i have mine in the lower part of the rear but because it's sideways you don't get as much use out of the bottle. it will be relocated very soon! i ran a 100 shot for quite some time without any problems. i wouldn't go above 150 on a stock system if you aren't planning to rebuild in the future. if you can't afford to fix whatever problem n2o causes keep the shot below 100 and more on the richer side of things.
absolute must that your car is in perfect running condition with good ignition and fuel flow.
