Blower "471 SINGLE QUAD SYSTEM"???
Car: 1984 z28
Engine: BBC
Transmission: TH400
I was looking at this B&M blower and I asked the guy what CID or air per revolutions is this. The dude knows nothing about blowers at all but he called the guy he bought it from and he said that guy said it was a "471 SINGLE QUAD SYSTEM".... What the heck does that mean?!?!!? It's a short snout single carb blower. I know they make 142, 144, 174, 177 and 256 CID single carb blowers but I have never heard of this 471 SINGLE QUAD SYSTEM. That does it mean? What CID is it or what number blower? Please help. Thanks
Car: 1985 Z-28
Engine: a big one
Transmission: 4 spd auto soon to be a 6 speed
he prolly meant a 4-71 blower. it is the size of blower that gm put on their 4 cylinder deisels, with each cylinder displacing 71 cubic inches.
if this is true, it is in the same class of blower that give you the 6-71 all the way up to the 14-71 blowers on the top fuel dragsters.
my .02
andrew
my .02
andrew
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
because these blowers are just blowers...and not a performance only part, theres alot of options out there.
there are 100s of bases out there to bolt that onto almost any motor... and there are a few top plate designs... the plate bolts on there and you put your carb(s) on top.... im sure someone out there has a setup for a single carb.... heck ive seen a setup for 4 sidedraft carbs before.......
Car: 1984 z28
Engine: BBC
Transmission: TH400
Thanks for your replys it helps a lot but doesn't really answer my question. I found this chart:
The first # is the blower # and the second is the CID that is produced.
Weiand 6-71
411
Weiand 8-71
436
Weiand 10-71
469
Weiand 12-71
497
Weiand 14-71
522
If it is a 4-71 which is probably is, then would it just follow the trend? The rend with this chart is about 25 CID per 2 diesel cylinders up. So would the CID of 4-71 be about 386?
Weiand 6-71
411
Weiand 8-71
436
Weiand 10-71
469
Weiand 12-71
497
Weiand 14-71
522
Get in touch with BDS (Blower Drive Systems). They would be able to answer that question most directly. The answer might be right on their website. I don't believe the ci/revolution comes up that slowly on bigger blowers but that's just guesswork on my part.
The smaller 142/144/177/256 blowers you KNOW how many ci it moves because the number directly corresponds to it's displacement.
Regardless, once you have your answer please remember that your engine only inhales every OTHER revolution. i.e. it's only inhaling HALF it's displacement with every engine revolution. That's how a little tiny 142 blower can keep up with a 350ci engine (plus it's over-driven almost 2:1)
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
LT1Formula
Oct 8, 2015 08:34 PM
