Anyone have Nitrous complications
Old Dec 29, 2003 | 07:09 PM
J's86ROC's Avatar
Car: 1986 IROC-Z
Engine: peanut cam LB9
I'm trying not to make this the same old post. I have read the articles in the tech section and feel confident, I just wanted to get a couple of opininos from those who have done it and used it for awhile.
I am going to be installing NOS 05151 in the near future on my 305. I was just wondering if anyone on here has had any trouble after doing a proper setup, and using it properly (when needed, not at every light. I knew a guy who blew up an LT1 doing that). I know there's always the chance of "catastrophic engine failure" However I'm talking on average.
Old Dec 30, 2003 | 09:51 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
sad to say, when that happens it is almost always, improper fuel pump output, fuel quality or timing issues. Once in a great while a motor that would have died prematurely of natural causes anyhow (poor factory quality control) meets its end just a bit sooner. I once read (this could be BS) that the internal stresses on a V8 only increase by 33% when HP on a 250 to 280 hp engine are doubled. There are a few math whizzes that could chime in here to give you more realistic dope.
Old Dec 30, 2003 | 05:22 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
hmm.....i could figure out those math equations, but i don't have a spare 20 minutes. Although it is usually always fuel, timing, or something else related...besides if something's going to break, it just might break a little sooner, but you're putting nitrous on for more power....not for more reliability.
Old Dec 30, 2003 | 10:02 PM
Chris B's Avatar
When your dealing with power adders and a stock motor anything is possible. My stock shortblock with 168k on the clock didnt fair so well under nominal N2O use. I expereinced a piston failure resulting in the distruction of the motor. Pics can be seen here. Broken Block The funny part was when it went let go it I wasn't sprayin. So bottom line. Stock parts just aren't made to last under any big power numbers.
Just my 2 cents
CCB
Old Dec 31, 2003 | 12:06 PM
300hpse's Avatar
Car: 1990 Trans Am
Engine: Lb9
Transmission: factory T5
Axle/Gears: 3.08 limited slip
chris b
what kinda shot were you runnun?
CarGuyDennis
137
Dec 6, 2016 11:02 PM
anesthes
Sep 18, 2015 12:34 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
FlyinLow89
Nov 12, 2001 02:35 AM
vortech305
Mar 30, 2001 12:21 PM
