Started on the turbo manifolds
Old Jan 7, 2004 | 02:11 AM
ta84-355's Avatar
Car: Trans Am -84
Engine: 355, Twin Turbo
Axle/Gears: 3.73 open
After years of planning and no garage I've finally started on the drivers side manifold. Pictures can be found here:
http://www.itv.se/~a1003/turbo/exhaust/exhaust.html
The compressor housing is about 1/2 inch from the hood, I'm afraid that it'll hit the hood when the engine rocks a little. Guess it's time to make a new fiberglass hood with raised scoop.
/Anders
Old Jan 7, 2004 | 11:12 PM
Friday128's Avatar
Car: 88 RS
Engine: some what of a 350
Transmission: dont got one
i dont know if its me but the pictures arent loading up
Old Jan 8, 2004 | 01:15 AM
ta84-355's Avatar
Car: Trans Am -84
Incredible, when I finally start on doing something interesting the server where I have my picture gallery has some sort of disc failure. It'll probably be back within two to four days :-(
I'll post when it's back.
Sorry for this.
/Anders
Old Jan 8, 2004 | 03:20 AM
ta84-355's Avatar
Car: Trans Am -84
Hmm, it seem to work all of a sudden - don't know how stable the server is right now. But the pictures are there now.
/Anders
Old Jan 8, 2004 | 02:16 PM
slickrock55's Avatar
Car: 82 Trans am
Engine: Twin turbo 350
What wall thickness tubing is that? It looks pretty beefy.
I've seen headers made from butt-weld 90º pipe fittings (from a plumbing supply store); has anyone heard of/had success with this? Seems it would be a lot cheaper than stainless steel, yet still hold up well and be able to support the weight of a turbo.
Old Jan 9, 2004 | 12:57 AM
ta84-355's Avatar
Car: Trans Am -84
They have 2 mm wall thickness (about 1/12 inch), plain steel - no fancy stainless stuff.
I've seen these bends being used on dragrace Volvo PV:s going low 10´s in the quarter. They will handle the heat but probably weight as much as a cast iron manifold. Quite easy to work with though. Tomorrow I´ll finish cylinder 3´s pipe and also start on cyl5 and 7. Damn, this is funny - but it takes a lot of time.
Thinking about the downpipe, I've got some 3" long radius bends laying around but I think I'll step down to 2.5" for clearance against the brake booster and steering shaft.
/Anders
Jake_92RS
Jan 28, 2020 10:37 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
transaero
Aug 31, 2015 01:14 AM
Bstrang6
Aug 26, 2015 11:39 AM
86White_T/A305
Aug 17, 2015 12:16 AM
