Injector question
Car: 85 Iroc-Z
Engine: 383, Vortech SQ
Axle/Gears: Stock 7.5 w/ shafts, 3:73
Injector question
I just got a Vortech SQ S-trim and I'm going to install it on my 89 Z. I'm converting to the 749ECM for timing & fuel. What size of injectors should I use. Should have approx 6-7psi on a 383 with a Miniram etc. Was thinking of a set of 36's, 38's. Or may be bigger?????
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Depends on fuel rail, octane in use, and HP of car.
How much HP you think your 383 will produce?
I'd think with the S trim 500hp is reasonable. If the inlet temps are down, we're talking 38# injectors at a reasonable fuel pressure.. (45lbs).
-- Joe
-- Joe
Car: 85 Iroc-Z
Right now I'm putting out 310rwhp, 420rw lb/ft. Probably going to go with about 6-7 psi of boost
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Hi,
6-7 non intercooled psi, after timing adjustments is around 130 hp, give or take.
I'd go with a 38#..
-- Joe
I'd go with a 38#..
-- Joe
Car: 1989 TTA #1240
Engine: 3.8 SFI turbo
Transmission: 2004r
Go the inexpensive route and get 868's they come om the sc 3800 v6's the are 38.5lb/hr. Should work nicely
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
