87 Iroc with Spray
Car: 1995 z28 Mystic Teal
Transmission: t-56
87 Iroc with Spray
How big of a shot could i put into my 87 Iroc 350 TPI without like having a great chance of killing my engine the engine just turned 100k
. Thanks a lot guys
. Thanks a lot guys Member
Car: 75 & 82 Z-28
Transmission: Saginaw 4 speed
Originally posted by Redballboy
haha thanks 125 sounds about what i thought it could take. Thanks a lot
i agree on the 100 for the street, but i'd say 150 is safe on the track... assuming you have the bigger fuel pump... on the stock fuel pump i wouldnt go over 100... even 100 can be iffy, also use the highest octane fuel you can afford/get your hands on, and get the safety switches (full throttle, fuel/oil pressure cut off) and a bottle pressure gauge mounted on the dash... some magazine did a test awhile back on a junkyard 350 with stock 150,000+ mile internals, and i believe it took like a 380 shot before blowing up, and the only reason it actually blew up it cause they hit the button at idle to purge it, and so it broke some ring lands.... of course a 300 shot would have broken something eventually, but still my point is i wouldn't be afraid of a 150 shot at all, as long as you have enough fuel, and can monitor everything
Car: 75 & 82 Z-28
Ive seen stock stangs run 200 shots (they also were just wanting to blow them up for an excuse to build a r302 or 351...). With enough fuel, and a good tune, 150 for a v8 really isnt out of the ordinary and I'd put it on a good running daily driver any day of the week.
Car: 75 & 82 Z-28
Originally posted by Cronic3rd
Um stock mustangs come with forged pistons (some of them at least). Not the cast crap chevy uses.
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
hypers are actually stronger than forged ones. They just tend to self distruct when detonation is present.
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
actually with a power adder, cast or forged pistons are recommended over hyper pistons. Cast and forged tend to melt rather than hypers which i believe just crack under failure. There was a long post about this in a previous thread but it went into great detail and my speed shop agrees with everything that was said, and they're the largest shop in chicago.
Car: 2002 Formula Firebird
Transmission: 4l60e
I am going to run a 75-100 shot on mine soon. However I know a guy with a stock l98 who runs a 150 shot on his. He hasn't even used a bottle yet so I couldn't confirm the longlivity or his internals. We will have to see.
Car: 1987 Formula 350
Engine: 6.0 boost and smak
Transmission: 4l80e
Axle/Gears: 9bolt 3.27
i have about 12 bottle ran through my totally stock L-98 at 150shot, almost 90,000 miles and i even had two backfires, hit it just under 3000, (both at the track trying to take some awd dsm's).... other then that it has all been very very fun...and the motor is as close to stock as possible...
Do the same to a set of hypereutectic pistons and you’ll have lots of little bits of aluminum everywhere. They’re strong, dimensionally stable, but brittle.
As far as how much, I know someone that was running 250hp in 2 stages (100hp off the line and 150 after the 1-2 shift) for 3 years before I lost track of him (in other words, it might still be running it, but I don’t know). I’ve run 175 without any noticeable negative effect on the engine.
Transmission: 4l60e
do you think I will be safe with a 100 shot on hyper pistons?
I will be running a 6al box with a 3000-5400rpm switch
Probably drop the timing to 6 degrees base...
I think that you’re safe running over a 200hp shot as long as you don’t mess up, but if you do mess up even a 50hp shot can hurt the engine, a 200 shot will just do it more dramatically.
Transmission: 4l60e
Well I think I will be ok...I have the fuel under control. A holley blue pump, T the main fuel line and run my holley fuel pressure reg to the fuel soleniod and let my mallory control the pressure to the engine. I don't think I should have any fuel problems.
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 11, 2015 03:17 PM
