can any one give me a heads up on the super fueler
Old Jan 10, 2004 | 10:09 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
i am just looking this thing and i would like some info on it i went to BlowerWorks.com but there site sucks. so i was wondering if any of you have this unit and how you like it how hard is it to tune and how close can it get to what you need for fuel demands.
Old Jan 11, 2004 | 09:07 AM
maniacc's Avatar
go here and follow the superfueler links...it has the whole manual in adobe form.
http://www.carrollsupercharging.com/oldsite/index2.html
later
larry
Old Jan 11, 2004 | 10:58 AM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I use it and really like it. However, when I convert to a 749 and 3-bar, I will be selling it because I won't need it.
Old Jan 11, 2004 | 11:02 AM
c4boom's Avatar
Engine: l98 and lo5
thanks i am stuck at the moment between the super fueler and the commander 950 this is for my 87 camaro iroc. yes i know its maf and that is the reason i was looking at the super fueler for a turbo setup.
Old Jan 11, 2004 | 11:19 AM
Willie's Avatar
It will work well with a turbo too. To calibrate the SF, first you set the start and stop points (boost) when you need additional fuel. From there, you have ten equidistant set points between the start and stop points. Each point can be sixteen adjustments, from zero percent pulse width to 100 percent. And if this isn't enough, the SF injector driver can handle both low and high impedence injectors. I have experimented with three 24# high-z and three 75# low-z injectors. Both work well.
Willie
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
BADNBLK
Nov 16, 2016 09:12 AM
NinjaNife
Aug 23, 2015 11:49 AM
86IROC112
Aug 21, 2015 07:20 PM
