6.5 - 7" 8 rib crank pulley for supercharger?
Old Jan 19, 2004 | 03:22 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
where can i find a 6.5" - 7" 8 rib crank pully for my eaton? i need one that will fit over the surp belt on thr crank, without hitting the sway bar.
ive pretty much run out of other places to look, so where should i be looking online to get one cheap?
ive been told that the ATI kits use a 7" pulley... i found a used 8" one online today, but with the 2.93" lightning pulley its 2.73 overdrive.... redline of 6k is 16382... eatons maps stop at 12k and i cant get a exact max speed... i know silverback has gone far over 14k, but i also know he does that for only 1/4 mile... thats about 10 seconds of boost...
the 7" one with the 2.93 would give me 2.38 overdrive.... thats 14334 @ 6k RPM.... lil more reasonable.
now i just have to find a 7" one... the only thing im really worried about is the crank and swaybar... they're kinda close...
where can i find them online cheap? 6.5 - 7" 8 rib pulley
Old Jan 19, 2004 | 10:54 PM
83 Crossfire TA's Avatar
heh... silverback on another board...
the M90 is being spun to 18K...
Old Jan 20, 2004 | 04:35 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
For those that asked, I "made" my crank pulley by using a crank pulley from a Super coupe, cut the outer 8 rib pulley from the inner by cutting completly through both pullies, about a inch back from the rearmost rib of the inner pulley.
I then took the outer 8 rib and welded it to a stock TPI crank pulley. The SC pulley just fits inside the TPI, just as it did prior. It is really a drop in fit, the 8 rib fits perfect. IIRC, the 8 rib is < .25" smaller diameter than the TPI pulley. cheers, Bob
Old Jan 20, 2004 | 05:45 PM
That sounds about like what my brother was doing initially, but later switched to an ATI pulley that he found on ebay...
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bigjay89gta
Oct 15, 2015 08:04 AM
anesthes
Sep 30, 2015 07:48 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
JSDaddy189
Sep 26, 2015 03:50 PM
