Nitrous/Fuel Supply
Old Jan 26, 2004 | 10:53 AM
Keith_Indy's Avatar
Car: 87 Firebird Formula
Engine: 305 LG4
Nitrous/Fuel Supply
I'm going to be putting nitrous on my currently stock motor this spring.
Currently I'm planning on the following:
Edelbrock Performer manifold
Rebuilt stock carb
75-100hp nitrous kit
headers, y-pipe
3" cat back exhaust
Will the stock fuel pump be able to handle the demands, or should I upgrade? And if I should upgrade, will a mechanical pump fit the bill or should I go electric?
Thanks,
Keith
Old Jan 26, 2004 | 11:14 AM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
What size is your motor? What kind of fuel pump does it have now?
Old Feb 9, 2004 | 09:39 PM
Keith_Indy's Avatar
Engine: 305 LG4
DOH!!
Has the 305, carb, stock mechanical fuel pump...
Old Feb 9, 2004 | 11:00 PM
MCas7's Avatar
If you are thinking about upgrading, it can't hurt. I believe that the stock pump will handle that amount of nitrous, but if you don't want to take any chances, then upgrade to a better (mechanical) pump. You really don't need an electric pump for such a small hit of nitrous. If you were running somewhere around 200 horse of nitrous, then I would reccomend an electric pump just for the nitrous system. I hope this helps.
300 posts WooHoo!!
Old Feb 10, 2004 | 07:05 AM
Keith_Indy's Avatar
Engine: 305 LG4
Thanks, that does help.
xodus2002
Jul 17, 2020 09:08 AM
nova983
European Region
Nov 2, 2015 12:15 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
James Sutton
Sep 23, 2015 01:56 PM
formula1LE
Sep 12, 2015 08:31 PM
