bigger injecters
Old Feb 1, 2004 | 01:23 PM
Jack G Jr's Avatar
bigger injecters
Hey fellas I am in need of some bigger injecters for the F1.I know you just can't slap some bigger one's in you need some kind of converter box.But where do I find one?Thanks
Old Feb 1, 2004 | 03:06 PM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Re: bigger injecters
Converter box.... why?
First injectors are available in Saturated type (which most F-Body ECM's use) up to 55 lbs.
If your running a boosted engine, then swaping to a 749 ECM and $58 code, along with a change of 2 resistors and 2 FETS will update the 749 for use with 8 P/H TPI type injectors. Then sky's the limit.
Changes to the Eprom will be needed with any injector flow change.
BW
Old Feb 2, 2004 | 03:04 PM
Jack G Jr's Avatar
Thanks for the reply Saturn5 but we won't be using the factory ecm.Will be going with Holley's c950 or FAST have not really decided just exploring my options.
Old Feb 2, 2004 | 03:12 PM
TTA850's Avatar
Car: 2013 C63C
Engine: M156 (P31)
Transmission: 7 speed MCT
Axle/Gears: AMG Limited Slip
If your going with a FAST then you can put whatever injector you feel like from stock to 160pph in there and tune for them.
Steve
Old Feb 2, 2004 | 03:24 PM
Jack G Jr's Avatar
Hey thanks TTA850 guess you learn something new everyday
PurelyPMD
May 5, 2016 04:57 PM
NZKnight
Oct 15, 2015 02:47 PM
racereese
Oct 10, 2015 09:39 PM
sjorgens
Oct 1, 2015 07:54 PM
