6-71 pulling balancer off motor!
Old Feb 23, 2004 | 10:54 PM
stevedave454's Avatar
Car: 91 S10
ok im asking this question for a friend of mine...
he has a 49 chevy truck, with a 327 and 6-71, it has 10:1 compression, i have no clue as far as timing, it has aluminum heads (he wont tell me what kind, or specs, but i suspect AFR) the thing runs wonderfully on 7lbs of boost, running 12.6's - 12.7's (at 5300 ft) but twice now he has put his 12 lb pullys on and both times half way down the track the entire balancer flew off.... the first time he assumed it was because the 327 crank didn't have the center bolt from the balancer to the crank, its only press on, and it sheared the keyway... so he ordered a new crank with the bolt in the center, well on the second run it happened again, i dont know if it stripped the bolt out or just broke it in half or what, but it did give out, and sheared the keyway again.... he's thinking it just because of the resistance trying to spin the blower that fast and that he just needs a dual keyway crank... but i think he definately has a problem what are your thoughts?
BTW i know that 12 lbs non intercooled boost, and 10:1 compression will scare a lot of you, but he is using race gas, and he says there is no audible detonation
this is becoming a very expensive problem seeing as how everytime it does this it destroys his lower pully, belt, balancer (fluidamper) and crank
Old Feb 23, 2004 | 11:07 PM
flrtin1's Avatar
Car: Z/28..39 Plymouth truck in progress
Engine: S/B
Transmission: Manual
I am running 9 lbs on a B&M Mega Charger which has a little more displacement than the "GMC" 6-71's. I only have one keyway and have not had any problems but I do know that they recommend the dual keyways
Old Feb 24, 2004 | 05:16 PM
614Streets's Avatar
Dude get him to double key a real hub on that thing. I would never use a big 6-71 with a "balancer/damper unless its a ati. Either buy a ATI made for blowers or get a Dyers or BDS blower hub and have the crank double keyed.
I had my crank double keyed to run 33% overdrive using a dyers hub.
Old Feb 24, 2004 | 05:30 PM
Car: 91 S10
i could be wrong about the fluidamper... i know he had one of those before the blower... if it helps it is the complete kit from holley, out of summit... i dont know if the kit comes with a hub like your talking bout or not, but it is single keyway right now, he already plans on getting the dual keyway so that should help
Old Feb 24, 2004 | 08:03 PM
614Streets's Avatar
Ya he will be a ok with a dual keyway.
italiano67
Dec 11, 2016 09:21 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Mickeyruder
Sep 2, 2015 02:45 PM
madsv1000
Aug 20, 2015 06:45 AM
86White_T/A305
Aug 17, 2015 12:16 AM
