3ld diesel turbo
Old Mar 2, 2004 | 12:25 AM
PILU's Avatar
Car: Firebird 89' and Formula 87
Engine: 2.8 l and 350 v8
Transmission: 2.8 Manual 5 speed and 5.7 manual 5 speed
3ld diesel turbo
I just got a holset 3ld turbo, I got it for five bucks, does anyone know if I can use it on my 350 carburator engine, the turbo doesn't have a waste gate, so im planing to put it with out the wastegate, would this be posible without damage to the engine.
Thanks.
Old Mar 2, 2004 | 04:01 AM
Cronic3rd's Avatar
Car: 98 Z28 vert
Transmission: automagic
Axle/Gears: 2.73 - boo racing yay MPG
If you got it for 5 bucks the person you got it form either - didn't care about it, didn't know what it was or knew it was broken. And start reading up and and use the search button. On a gas engine using a turbo with out a waste gate is a bad idea - things go boom.
Old Mar 3, 2004 | 07:25 PM
stevedave454's Avatar
Car: 91 S10
the wastegate is what basically controls/limits your boost, so with out one you'll run WAY too much boost, but you can use an external WG, and on a carb you'll need it rebuilt for "blow through" those 2 things are a couple hundred each, then you need turbo headers/manifolds, intake piping, and intercooler is strongly recomended... you can do it, but you'll be into it a grand if not 2 grand. and like the cronic3rd said, good chance the turbo doesn't work
Old Mar 3, 2004 | 08:01 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
its a 3ld or does the tag say GM-3?
Old Mar 4, 2004 | 05:13 AM
PILU's Avatar
the tag says holset type 3ld..
yea the turbo isn't in best shape, the compresor wheel is a little mest-up. Yeah I didn't think i could use it , i just got it because it was really cheap.
anyway, my firebird runs pretty good, it is a 350 5 speed, with alot of racing stuff, but i want to make it fly, I guees i'll have to gather some money to put a decent turbo in.
sorry about the spelling english is my second lenguage
Old Mar 4, 2004 | 06:37 AM
SATURN5's Avatar
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
No worries.... Your spelling is better than some for whom English is their "native" language..
BW
Old Mar 4, 2004 | 01:25 PM
83 Crossfire TA's Avatar
3ld doesn't really tell you much… it's just a series name, somewhat like saying it's a T3 or a T04… it could still be big or small…
Also, I believe that there are 2 3ld's, one that was used on a bunch of marine and truck apps from about '64-77, and another one that was used on small marine applications around '95. Both are on the smallish side, most would top out around 250-300hp or so, but there is one that appears to be good for about 450-500hp. How about a little more info? Even something like inducer size would give you some idea of what power level it would work for. Also, there is usually a 2 digit marking on the turbine side that will tell you how big that housing is (I suspect LARGE, since I don't think that any of the applications were wastegated on diesels, both things that would imply a biger turbine housing).
Old Mar 4, 2004 | 07:42 PM
PILU's Avatar
the only two digit number that i found is f. 32.
The assy number is 53925 / 14.
I think the inducer size is 3 inches.
Doyou think is a good idea to fix this turbo and get an external wastegate?
Old Mar 4, 2004 | 11:44 PM
If the inducer size is actually 3" then that is a pretty good sized turbo, but doesn't match anything that I've described so far. Barring more information (the assembly number doesn't seem to translate to anything that I can find) I'd only be guessing, but I doubt that it would be worth putting any effort into. I suspect that the compressor size is roughly similar in flow to a T3 (you'd need 2 on your 350) and the turbine side is too big to be useful on most gas engines.
Old Mar 4, 2004 | 11:56 PM
PILU's Avatar
thanks, I guest i better gather some money and buy a decent turbo.
cheesehomer
Dec 31, 2015 08:48 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
school boy
Oct 22, 2015 11:47 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
