Nitrous Fuel Line T-fitting Question
Subscribe
Mar 10, 2004 | 11:21 PM
Well I went to home depot and got all the fittings to T into my fuel line and the necessary adapters from my speed shop, my question is: What should I use to seal the threads? Teflon paste? Is using teflon safe on these threads with fuel running through the fittings?
Tony
Reply 0
Mar 11, 2004 | 10:59 AM
Re: Nitrous Fuel Line T-fitting Question
Quote:
Tony
You want to use teflon paste, not teflon tape. Pieces of teflon tape can wreak havoc on your fuel solenoid.
Reply 0
Mar 11, 2004 | 02:43 PM
I agree with unknown, but you can use tape as long as it doesn't come close to the hole of the fitting.
Reply 0
Mar 11, 2004 | 05:59 PM
paste
Reply 0
Mar 11, 2004 | 11:34 PM
Most Teflon paste has some good size chunks of Teflon in it. Getting that stuff in the lines is almost as bad as some tape.
Most fittings that should be used for fuel shouldn't need anything additional to seal them. If you insist on using some thing with a tapered thread (pipe thread/npt…) then I would recommend a sealant rated for natural gas/propane lines or something like hylomar…
Reply 0
Mar 12, 2004 | 08:30 PM
Thanks guys
Reply 0
Subscribe
