Procharger with D-1SC question?
Old Mar 17, 2004 | 06:30 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Engine: Procharged 406.
Axle/Gears: Moser 9" 4.11 Gears
What size is the piping that comes with the D-1SC kit? Also what size O.D. is the inlet/outlet of the three core intercooler? My Throttle Body is 2" higher than a normal TPI design and i'm thinking I may need to bend a new inlet tube, if I purchased the kit.
Old Mar 17, 2004 | 07:11 PM
maniacc's Avatar
3" o.d. piping....3" in/outlet on the intercooler...as you should not have any problem hooking up the system even with the raised throttle body height.
later
larry
Old Mar 18, 2004 | 09:53 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
cool. Is there any benefit with going to a bigger pipe, maybe 3.5" or 4"
Old Mar 18, 2004 | 02:26 PM
maniacc's Avatar
I don't believe that there would be, seeing that outlet on the blower and the in/out on the intercooler are both 3", you may actually lose velocity.
But i have been known to be wrong.
later
larry
Old Mar 18, 2004 | 03:13 PM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
i'll keep that in mind. Thanks. If anybody else wants to chime in please do so.
Old Mar 18, 2004 | 09:29 PM
biggtime's Avatar
3" into the intercooler is fine as it gets cooler it is denser so you could go to 4" out to the TB, but packaging it might become a issue. You throttle body is also 4". I used 3" in and out. plenty big enough to support my end goal of 700 at the crank.
Old Mar 19, 2004 | 10:51 AM
1 DwnCam's Avatar
Car: 92 Z28 Camaro
Yeah my goal is 700ish also. So then just use what they package with the system?
Old Mar 22, 2004 | 01:32 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
I am thinking of getting this same supercahrger. I know I am going to have to bend a new inlet pipe......I am going carburated. Does anyone have any pics of the ATI kit installed? Or even some of the kit uninstalled?
Old Mar 22, 2004 | 03:25 PM
maniacc's Avatar
look at the sticky post at the beginning of this thread, "post pics of your power adders" there are kits installed on both carb and fuel injection.
later
larry
Old Mar 23, 2004 | 02:57 PM
XJOSHX's Avatar
Car: 1988 Iroc-Z
well I was leaning more towards the 3 row intercooled D1 kits.....I think I might of seen one single d1 kit in the post pics sticky.
MustangBeater20
Oct 29, 2022 09:20 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
