how much power can be expected?
Old May 13, 2004 | 01:00 PM
Dante93GTZ's Avatar
Car: 1992 Z28 Heritage Edition
Axle/Gears: 3.23:1
This is just a rough spec sheet of what I hope to build.
400 sbc
8.5:1 to 9:1 C/R
forged internals
1 3/4" primaries on the twin turbo headers
Two T04 turbos
2 small volvo/probe intercoolers
Holley StealthRam with 24# injectors
Custom burned chip as yet to be determined
3.5" single exhaust
I know this is sketchy but tio those who have built boosted motors... How must boost would u run? What kind of power can be expected from this type of setup?
Old May 14, 2004 | 01:11 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
ANYONE?!?!?
I see how it is... keep the same topics alive, but never give the new ones a chance!
Old May 14, 2004 | 04:06 PM
83 Crossfire TA's Avatar
Between 0 and 30psi and between 0 and 1600hp
Old May 14, 2004 | 05:24 PM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
Well, that just about clears that up. Thanks for the "help".
Old May 14, 2004 | 07:23 PM
88 350 tpi formula's Avatar
Car: 89 FORMULA 350, 91 Z28 Convertible
Engine: ls1, LB9
Transmission: t56, Auto
Axle/Gears: S60/ 3.73
well, 24# injectors will keep your hp low. unless you want to run lean. I would look at 30# injectors just to get above the 400 hp mark. do a search and you will find the formula needed to find injector sizing for expected hp.
Old May 15, 2004 | 11:47 AM
Dante93GTZ's Avatar
Axle/Gears: 3.23:1
What model or type of injectors are 30#? Where can I get some?
Old May 15, 2004 | 08:50 PM
automec's Avatar
Car: 82 Z-28
Engine: 408
Transmission: TH-400
Axle/Gears: 4.11
adam with the chevy luv that u looked at just went with 75lb injectors and he is also a turbonetics dealer .
mike
Old May 16, 2004 | 12:08 PM
Engine: ls1, LB9
I am guessing that this stuff is pretty new to you. I would suggest that you read through other posts and try and find out as much as you can first. I would hate to see you jump into a turbo setup like that and find your self inthe middle of it all with no clue.
BRoss99
Aug 10, 2025 05:08 PM
Cornholio7979
Sep 20, 2018 02:31 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
sailtexas186548
Aug 24, 2015 10:11 PM
ezobens
Aug 19, 2015 10:29 PM
