My twin turbo headers!
Old May 25, 2004 | 07:04 PM
zz4z28's Avatar
We just finished them last night!
they are going on an 86 z28 with dart little M block, JE 4.155" dished blower and nitrous pistons, oliver billet rods(6 inch), callies 3.75" crank, AFR 210 comp. port heads with manley severe duty valves 2.100, 1.60. Dart wilson single plane manifold, lunati .606 .600 lift .258 .264 on 114 lsa solid roller cam!
the headers are t304 stainless steel, and the primary tubes are all exactly 19 inches long, the headers are identical on both sides except the pass. side is a little longer after the collector to clear the alternator.
I am using precision sc61 turbos with t4 .81 exhaust housings and t04s comp. covers, tial 38mm wastegates, and a 90mm throttle body!
Old May 25, 2004 | 07:05 PM
zz4z28's Avatar
oh and by the way they mount so the collector turns down, to give you an idea.
Old May 25, 2004 | 07:06 PM
zz4z28's Avatar
one more
Old May 25, 2004 | 07:17 PM
superirocz's Avatar
excellent:yourock:
Old May 25, 2004 | 07:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Verrry Nice looking. One of the Best set of TT headers Ive seen on this board.
Old May 25, 2004 | 11:33 PM
scottland's Avatar
Car: '82 Z28
Engine: 350HO
Transmission: M4
Those are incredible. quite possibly the nicest set of turbo headers i've ever seen.
Old May 25, 2004 | 11:36 PM
OMINOUS_87's Avatar
Yo fool, what did they end up settin you back.
They kick **** though in the end.
Hopefully you got all the BS settled with AFR about your heads.
Old May 25, 2004 | 11:52 PM
zz4z28's Avatar
around $1000 for them!
a screamin deal compared to what I could have paid.
they let me go through all their scrap bends and save some serious cash.
them ost expensive part was the collectors, but they were absolutely perfect inside and out!
they look even better in the car with turbos mounted up!
Old May 26, 2004 | 12:12 AM
OMINOUS_87's Avatar
1000$
Thats some ivy league sheet you got bro, good score!!!!!!!!
Old May 26, 2004 | 12:28 AM
25THRSS's Avatar
Old May 26, 2004 | 04:40 AM
83 Crossfire TA's Avatar
Those are some trick looking headers… nice.
That being said, I’m betting that you wouldn’t be able to prove a higher average HP over a set of well built log manifolds with an otherwise similar setup.
Old May 26, 2004 | 07:24 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
who cares if he makes more HP over some UGLY *** logs. Those are deff alot nicer.
$1000is cheap for a set uf headers like that OMINOUS_87. I almost droped $1200 on a set from Innovative turbo and Thats down from $2000 thay He wanted. but I desided I wanted to go a cleaner more header like prestons setup.
Old May 26, 2004 | 07:38 AM
90ludepunkfl's Avatar
They look great! $1000 isn't too bad for them.
Old May 26, 2004 | 07:42 AM
As for more hp over a stock chopped log manifold........it should make more hp I would assume since it will flow better.....With import turbo setups almost always the log manifolds made less hp then the nice (expensive) manifolds.
Old May 26, 2004 | 07:45 AM
Guido's Avatar
Car: 2000 Trans Am
Hey ZZ4, where did you obtain those flanges? Ive seen them on a few sets of headers, but never knew where to get them.
For comparison, I had about $1000 in my old set for the SBC as well and this is how they turned out:
Old May 26, 2004 | 07:49 AM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Curt, Yours looked great also for a single setup.
$1000 is about right for a DIY 304ss setup. It was right around $850+ for material from Stainless Works
Old May 26, 2004 | 08:03 AM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
http://www.burnsstainless.com/MergeC...ollectors.html
Old May 26, 2004 | 11:05 AM
Guido's Avatar
Car: 2000 Trans Am
I didnt mean the COLLECTORS Joby. I knew where to get those. I mean the flanges that bolt onto the heads.
Old May 26, 2004 | 11:18 AM
OMINOUS_87's Avatar
Oh I know, I fully agree that $1000 is a really damn good price.
I dont think its high at all for what he got, that is one dope setup.
I eeked BC I couldnt believe how good a deal he got.
Old May 26, 2004 | 12:12 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
?? Am I missreading something but didnt he build them himself? or ???? Either way Absolutally stunning headers. Now Im really getting the bug to go get some gas for my tig and go rummage through the Junk/scrap at stainless works and get started on mine.
Old May 26, 2004 | 04:07 PM
96BlownSSragtop's Avatar
Car: 89 Formula
Engine: Nada - v4.0
Transmission: Nada - v3.0
Axle/Gears: Nada - v3.0
Probably here:
http://www.spdexhaust.com/
Old May 26, 2004 | 05:32 PM
Like I said, I think they do look sweet…
To put it in perspective, figure the supplies used cost 2-3x what BBS uses and it’s a lot more work…, so yea, $1k is a smoking deal.
FWIW, If you’re looking for something like preston’s setup, then what difference does it make? You can’t see his headers/manifolds anyway.
Woa, no one ever said anything about a “stock chopped log manifold,” a properly designed log manifold is significantly different. Even OEM turbo manifolds are designed for durability and packaging first, and if you’re going to bring a factory f-body manifold, chopped and welded to run a turbo into the picture, well, cut one up and you’ll find plenty of problems. Even with that being said, cut and welded OEM manifolds will work more then well enough to blow up 99% of the engines that people are interested in turbocharging.
Peak HP… yea, it’s possible, but I’ve seen quite a few back to back dyno tests that do not agree with that, and I’ve never seen a tubular manifold make more average power then a comparable “log” (again, it’s not really fair to compare something with 1-3/8” primaries and a 1-3/4” outlet to a tubular 1-3/4” primary/3” outlet, is it?)
Old May 26, 2004 | 06:42 PM
zz4z28's Avatar
curt- I got all the flanges and collectors from SPD.
they did an awesome job on them, I was very impressed with their product.
I did not buuild them myself I had thedesign made up by a company called spectrum 5 racing, and then I had a friend of mine build them with me because he has built turbo headers before, and I knew they would turn out allot better with his experience!
I would think that they would perform better than a log manifold, but I will never put one on my car to find out, I had a friend with a log manifold single turbo ls1 and when he had tubular headers made for it, it was a whole new car, tons more power, but it could've been that he had a bad setup before.
Either way I am absolutely stoked to get this thing running, when I get some pics of them in the car I will post em up!
Old May 26, 2004 | 07:40 PM
89JYturbo's Avatar
Car: 89 Camaro IROC-Z
Engine: Intercooled Twin Turbo LQ4
Transmission: Tremec TKO 600
Those headers are true artwork! I'm very impressed.
Old May 26, 2004 | 10:46 PM
trans slam's Avatar
A big clap from my corner of the garage, well done to who ever made them.
Old Jun 5, 2004 | 08:36 PM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
Looks alot like Monty's headers. Can't remember what he paid for his, but im sure it was more.
Old Jun 8, 2004 | 11:50 PM
zz4z28's Avatar
i believe monty used 321 stainless
Hotrodboba400
Dec 10, 2019 07:07 PM
86Firebird86
Dec 26, 2015 07:21 AM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
