n2o and proms
Old Jun 27, 2004 | 08:34 PM
snapping turtle's Avatar
n2o and proms
I whould like to run a dry 100 shot on my car using the nos kit #5115 . I have a custom burnt chip in it now for the motor only . I did not plan on using n2o at the time of the motor built , but you know how that goes . My guestion is can I use the n2o with that prom with the more aggressive timing in it . I have an msd 6 plus with a timing retard on it to take the timing out for the n2o . Will this be ok , or will this be TROUBLE !! THANK YOU
Old Jun 27, 2004 | 09:36 PM
25THRSS's Avatar
if you retard the timing with the box it should be fine
Old Jun 28, 2004 | 06:51 AM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Transmission: Powerglide
Axle/Gears: Moser 31 spline / 4.86
Re: n2o and proms
A dry 100 shot wouldnt be a good idea. Get a kit that mixes fuel with the nitrous..
Old Jun 28, 2004 | 02:34 PM
Thanks for the help . I running a super ram on my set up . I was told by alot of people not to run that with a wet kit due to puddlind in the super ram . Sorry I left that info out on the original post
Old Jun 28, 2004 | 02:44 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
I'm not too familiar with the super ram.... But i would think that it would suck down the nitrous and gas all together. If you do run it dry, bring your timing down atleast 10 degrees.
Old Jun 28, 2004 | 02:45 PM
1bad406's Avatar
Car: 1987 Camaro
Engine: 406
Im not too familiar with the super ram. I would think that the nitrous and gas would all go down together. But if you do run it dry, bring your timing down atleast 10, maybe 12.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
dusterbd
Sep 29, 2015 08:40 AM
BLK87Z
Sep 18, 2015 11:29 PM
Winchester1094
Sep 15, 2015 09:48 AM
