turbo fuel maps
Old Jun 29, 2004 | 07:51 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
Engine: Dart Little M Twin Turbo
turbo fuel maps
I've been having an issue with getting drivability improved on the Z28tt, and was wondering how your fuel/timing/accel enrichment was programmed. I've already increased the MAP enrichment from 10% to 22%, and still get a lean pop on stabs of the throttle. The TPS enrichment is at 4ms asyc pulsewidth (adds 4ms of fuel to the base pulse), so I guess I should bump that up too... FWIW, the package is 399 cid, AFR210's, Pro-ram single plane intake, gale banks tt manifolds, T04e's, and 2.5" downpipes.
Old Jul 1, 2004 | 03:05 PM
xtremeirocz's Avatar
Car: 1986 Irocz- Houstons Fastest Street
Engine: 408 LS1 w/ 2 stage
Transmission: Turbo 350
Axle/Gears: 3:73,3850 lbs , best of 9.92 @ 138
what kind of dfi? on my f.a.s.t. system it is pretty easy to tune with a dyno. what system do you have? it shouldnt be hard with some dyno time and good o'2's
Old Jul 3, 2004 | 09:04 AM
askulte's Avatar
Supporter/Moderator
Car: '89 Z28tt
It's a DFI Gen 6. I added pulsewidth to the TPS table, and all is well now. WOT was good, so the dyno will come later when I start optimizing the timing tables at WOT.
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
R3500
Aug 17, 2015 12:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
